Plex on Synology using all resources
Can you paste in Command Prompt?
Yes to IP. Not to auto block. Will try that next.
Still won’t let me login. After a few times it says permission denied (publickey,password).
SSH is enabled. Default port is 22. Had on firewall, turned that off just in case, no difference.
I tried with both the account I had enabled for administrative purposes, and reenabled the standard administrator account. I’m copying and pasting the password from my password manager. I can log in by typing the IP in my internet browser but keep getting these messages when trying to do so through command prompt.
C:\WINDOWS\system32>ssh elpianoman@192.168.86.31
elpianoman@192.168.86.31’s password:
Permission denied, please try again.
elpianoman@192.168.86.31: Permission denied (publickey,password).
C:\WINDOWS\system32>ssh admin@192.168.86.31
admin@192.168.86.31’s password:
access denied for both elpianoman and admin on PuTTY.
I don’t think Ctrl + V was working. Typed in the admin password and it looks like I’m in. Could not chdir to home directory /var/services/homes/admin: No such file or directory
admin@Drobnast:/$
admin@Drobnast:/ ps -ef | grep -i plex plex 19691 1 99 16:10 ? 04:48:33 /var/packages/Plex Media Server/ target/Plex Media Server plex 19861 19691 0 16:10 ? 00:00:22 Plex Plug-in [com.plexapp.system ] /volume1/@appstore/Plex Media Server/Resources/Plug-ins-79e214ead/Framework.bu ndle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.19.4.2 935-79e214ead /volume1/@appstore/Plex Media Server/Resources/Plug-ins-79e214ead/ System.bundle plex 20711 19691 0 16:10 ? 00:00:02 /volume1/@appstore/Plex Media Se rver/Plex Tuner Service /volume1/@appstore/Plex Media Server/Resources/Tuner/Pri vate /volume1/@appstore/Plex Media Server/Resources/Tuner/Shared 1.19.4.2935-79e 214ead 32600 /waitmutex plex 23124 19691 37 16:25 ? 00:40:41 /volume1/@appstore/Plex Media Se rver/Plex Media Scanner --scan --refresh --section 3 --activity 00107896-f034-45 9f-9162-3f23dc6e3279 admin 29181 28222 0 18:15 pts/16 00:00:00 grep --color=auto -i plex admin@Drobnast:/
Do I enter Free after hitting enter for the first string?
admin@Drobnast:/$ free
              total        used        free      shared  buff/cache   available
Mem:       16235008     1031680     9919324       10408     5284004    14673204
Swap:      11837356      339524    11497832
admin@Drobnast:/$ admin@Drobnast:/$ free
Are both of those what you were looking for?
Great! Definitely not super experienced on the command line stuff. Thanks for bearing with me.
I said not “super experienced” My dad and I worked through some stuff when I was real young and command line was much more common! Lol. Definitely don’t do much/any today though.
9GB of memory is completely unused.
5GB of memory used for disk buffers (zero cost boost as they are instantly given back when needed)
It’s not using all the memory. It’s using just over 1 of the 16 GB for applications, 5 for buffers.
1048576 * 1024 = GB
this is using 1031680 (slightly under 1048576) :slight_smile:
Yeah, now. LOL. I had stopped and started the service earlier today in order to be able to log in to update my libraries. As it stands now, my cpu is lower at 58 percent and ram is showing 7%. BUT before I stopped the service, the cpu was pegged for days at 98 percent and the ram was similarly as high. I had stopped and started the service every couple of days when trying to use the diskstation because it was so tied up everything was super slow or unresponsive. I’ll keep an eye on it and send the same reports when I notice the ram is high again. Would the same reports work for high CPU or is there a different report you would want me to run?
Do you need the DLNA server?
If you don’t, turn it off. It is a very well known memory leak.
It’s off by default because of that until such time as Engineering finds it.
