Plex stopped connecting to my Unraid library shares
Server Version#: 1.40.0.7998
Player Version#: 10.9.0.5676
My plex server running in docker on my unraid recently stopped being able to see my library of content on my unraid shares. I get this in the plex server when trying to view the library:
And I get this when I look at the logs in the docker container:
cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
Stopping Plex Media Server.
[cont-finish.d] executing container finish scripts…
How do I trouble shoot this issue further? It’s been running great for about 6 months now.
I found the Plex Media Server.log file and found these errors:
Feb 14, 2024 08:26:58.339 [23361627572880] ERROR - SQLITE3:0x80000001, 11, database corruption at line 72267 of [a29f994989]
Feb 14, 2024 08:26:58.339 [23361627572880] ERROR - SQLITE3:0x80000001, 11, statement aborts at 3: [SELECT value FROM ‘main’.‘fts4_metadata_titles_icu_stat’ WHERE id=?] database disk image is malformed
Feb 14, 2024 08:26:58.339 [23361627572880] ERROR - SQLITE3:0x80000001, 11, statement aborts at 10: [UPDATE metadata_items SET extra_data = NULL WHERE id IN (SELECT value FROM json_each(?))] database disk image is malformed
Feb 14, 2024 08:26:58.339 [23361627572880] ERROR - Exception inside transaction (inside=1) (/home/runner/actions-runner/_work/plex-media-server/plex-media-server/Library/DatabaseMigrations.cpp:292): sqlite3_statement_backend::loadOne: database disk image is malformed
Feb 14, 2024 08:26:58.340 [23361627572880] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database disk image is malformed
Feb 14, 2024 08:26:58.465 [23361627572880] DEBUG - ChangestampAllocator: initialized to 289404
Feb 14, 2024 08:26:58.490 [23361627572880] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1
I already ran the PRAGMA integrity_check; command on the com.plexapp.plugins.library.db file and it came back ok. Are these errors saying some other db is corrupt?
Been having this exact problem for several weeks now. It usually works for me to restart the Plex server docker - everything then shows up. But I have not had any success figuring out why it is happening. I have updated Plex server twice since it has doing this and it has not gotten better. Did you figure out anything on the errors you are seeing related to the database?
