Server Version#: 4.5.3.1652
Player Version#: 1.23.0.4459
When trying to install most recent two upgrades of PLEX Media Server, QNAP App Center fails with the error:
Unable to install the package. For details, see “System Event Log”
-PlexMediaServer-1.23.0.4459-20536d6fc-x86_64.qpkg
The System Event Log shows only a message saying “[App Center] Failed to install PlexMediaServer-1.23.0.4459-20536d6fc-x86_64.qpkg. Try again later.” and no other details. Plex logs show nothing relevant. SHA1 hash of downloaded file matches that shown on download site.
Thanks ChuckPa. After stopping Plex (it’s disabled) and restarting my QNAP, it still gives me the same errors on install, both to the screen and the System Log. When I enable Plex, it works fine, just still running the old version.
Other ideas?
OK. Those steps worked. Unsure why it didn’t if that’s how QNAP does it.
Firmware version is currently 4.5.3.1652. Model is TS-451+ (Intel chipset. No NVIDIA) Same problem was happening on previous version (Which is why I upgraded. I don’t usually since Plex is my priority, until it’s proven stable in the forums.)
SSH Console is below. Though if it worked, I’m not sure it’s valuable…
Thanks for your help. Let me know if there’s anything else I can do to help for the future
SSH StdOut:
[/share/Public] # chmod +x PlexMediaServer-1.23.0.4459-20536d6fc-x86_64.qpkg
[/share/Public] # ./PlexMediaServer-1.23.0.4459-20536d6fc-x86_64.qpkg
Install QNAP package on TS-NAS…
./qpkg.cfg
./qinstall.sh
./package_routines
./built_info
4455+1 records in
4455+1 records out
110565988 bytes (105.4MB) copied, 1.394243 seconds, 75.6MB/s
107973+0 records in
107973+0 records out
110564352 bytes (105.4MB) copied, 1.395295 seconds, 75.6MB/s
PlexMediaServer 1.22.3 is already installed. Setup will now perform package upgrading.
Firmware check is fine.
Stopping Plex Media Server…
Link service start/stop script: plex.sh
Set QPKG information in /etc/config/qpkg.conf
^[[DStarting Plex Media Server…
[/share/Public] #
Considering I was ignored the last two times I posted and I actually paid for this service, I thought it might be worth the subtle “hint”. Seeing as how it actually got a response for once, it looks like it’s a Keeper…
Hey ChuckPa. I did indeed hit left arrow when I was swapping back to the session. It’s running and upgraded now. Unclear why it failed with their App Store interface. If there’s any logging from QNAP I can get to you, just let me know from where.
Same problem for PlexMediaServer-1.23.1.4528-c0513eb4c-x86_64 installation. Manual installation per above instructions works. I realize that my console login is the root and my GUI login is an Admin User.
I’m unblocked for now. If there’s additional steps to make this problem go away in the future, please let me know.
We’ve had multiple users install current packaging, on both QTS, and now QuTS without incident. The issue is unfortunately isolated to you.
If App Center is still failing for you after upgrading to current firmware (4.5.3.1670) , please contact QNAP. They will need to help fix it for you. Whomever you speak with cannot say “It’s a Plex problem”.
It is the newest Firmware (.1670) and I understand your position. Other packages have installed correctly so I’m honestly quite confused with this. Issue appears isolated to Plex from my perspective.
I can try to reach out to QNAP, but they’ve not been very helpful in the past. Thanks for providing a methodology to succeed. At least I’m unblocked.
OK. Managed to get SSH setup for my QNAP User account. Below is the install log for the most recent upgrade. Looks like a bunch of permission issues. Not sure why it would have been changed., but is there a repair I can do for the Plex permission structure?
Looking closer, ls -l shows that the files are indeed marked as owned by ‘admin’/‘administrators’. My User account (Scott) is shown as a member of ‘administrators’.
OK. So like I said, I’m not sure how it got into this state. I used to be able to update Plex from the GUI as Scott. Should I chmod -R on all the files to allow me to update? Or is there a safer/better way to do this?
Can you log in as admin, not scott, and use Manual Install?
If you can’t then you must get QNAP , on a teamviewer session, to help you fix whatever is wrong with your QTS installation.
If you were able to perform the Manual Install successfully, it is probably worth asking QNAP to help you find out why you can’t as a user in the administrators group.
We do everything as the admin user to avoid this type of situation and is part of the QNAP documentation so I don’t really know how it should work.
