Plex pass , skip intro
Hello, I just subscribed to Plex Pass, in order to skip the intro and remote broadcasting, etc., and I previously had movies and series attached to my Plex account, but I did not see the intro skipping and when I click on analyze the movies, it does not analyze them. What is the solution? Please help. Because I have many movies and series, I want to analyze all of them with one click.
Analysing them all could take hours. Check activities to see if it isn’t already running.
Also, check you have it enabled for each library.
Edit: Also check whether you have it to run during maintenance schedule (you might want to increase that window until it has completed).
I swear to you, the activities do not work. I tried many times. I click on the movies and then analyze them, but it does not analyze them. When I click on a specific movie, such as Fast and Furious, it analyzes it. I will lose my nerve from this thing. Please help.
Unfortunately, I removed my home cloud for movies and TV shows, and downloaded them again and they are now processing, I guess I have no other choice.
There is no intro to analyze for Movies, such as Fast and Furious.
Yes dear, there is a skip credit at the end, and it also helps me know if there are any hidden ending shots at the end of the movie, try it yourself, Fast and Furious 1 has an ending shot
Plex supports finding the end credits for movies but not intros.
Movies - end credits
Shows - intro and end credits
Every single time you asked for help, you mentioned “intro”, not “credits”. You even tagged the post with the forum tag “Intro”.
Wanted to make sure you were aware that there is no intro to skip in movies.
