How do I remove the ribbon at the bottom of the screen with the play features and on my browser tab, it has the name of the movie
The mini-player / control bar should go away when you stop the stream.
Note: if you have autoplay disabled the player exits in a paused state essentially when playback of a program ends and you have to manually click Stop to close it.
When playback finishes the web app changes to the next episode’s pre-play screen but still has the ribbon from the previously played episode at the bottom. Perhaps might make more sense to exit back to the pre-play on the episode that we just finished, since we already set our preference to not auto-play, or maybe leaving it on the next episode pre-play is fine. But it doesn’t make sense to have the control bar still active if playback is now done.
it does not
