Plex Player does not detect if it is starting off screen on startup
Server Version#: 1.40.0.7998-c29d4c0c8
Player Version#: Version 1.88.1.96-c1c59fc1
Microsoft Windows Version 11 23h2 (Build 22631.2428]
I generally place the plex player window onto my 2nd screen as it is larger
Today I turned off my 2ns screen using the windows 11 projector options and selected single screen only turning off the 2nd screen, the same may happen if i select mirror displays? that i have not tested
Then i started the plex player it loaded but started off screen and did not re-centre itself to make itself visible, i had to turn my 2nd screen back on to see the plex windows so i could move it to my primary display
The point is, if plex player is closed while on a screen that is then turned off in display options, when plex is run if that screen is off the plex window is inaccessable
