Plex window missing after removing second screen
The PLEX player window is not showing after disabling second screen.
Steps:
Running plex windows on a second screen. (dual screen)
Closing plex.
Remove second screen from display settings disable second screen option, so it is not vissible
Only screen 1 is active now.
Starting plex windows on first screen. Does start, icon in taskbar, but there is no window.
This works to fix:
Selecting MAXIMIZE WINDOW from taskbar item brings the window back
Alternatively, use these Windows keyboard shortcuts, which would work with any app window:
Press Alt+Tab to select the lost window, then hold the Windows key and tap the left or the right arrow key to snap the window back onto the screen. On Windows 10, you can right-click the taskbar and click “Cascade Windows” to move every window back onto the desktop.
