Plex Plug-in Kickstarter
Not sure if i am in the right place for this post, first of all i am quite new to Plex forums and i just bought a Plex pass to get all the neat new features :) which are great buy the way awsome work
my problem is im trying to make myself a few simple Youtube plugins from the Plex Plug-in Kickstarter page in Dev tools and with no luck i cant get them to show up on the server or work!! :( can someone maybe help me with this? i think its maybe some code within the app "__init__" file but cant understand the problem.. i will post the code below along with the feed i am trying to set up along with username from Youtube if that helps many thanks for helping guys  :D
Youtube Channel: http://www.youtube.com/user/BFvsGF
Youtube Name: BFvsGF
Code:
from datetime import datetime
import time
import re
PLUGIN_PREFIX = “<?= $VARS['prefix']; ?>”
FEED = ‘<?= $VARS['feed']; ?>’
YOUTUBE_VIDEO_PAGE = ‘http://www.youtube.com/watch?v=%s’
YOUTUBE_VIDEO_FORMATS = [‘Standard’, ‘Medium’, ‘High’, ‘720p’, ‘1080p’]
YOUTUBE_FMT = [34, 18, 35, 22, 37]
NAME = L(‘Title’)
make sure to replace artwork with what you want
ART = ‘art-default.jpg’
ICON = ‘icon-default.png’
def Start():
Plugin.AddPrefixHandler(PLUGIN_PREFIX, Menu, NAME, ICON, ART)
Plugin.AddViewGroup(“InfoList”, viewMode=“InfoList”, mediaType=“items”)
Plugin.AddViewGroup(“List”, viewMode=“List”, mediaType=“items”)
MediaContainer.art = R(ART)
MediaContainer.title1 = NAME
DirectoryItem.thumb = R(ICON)
VideoItem.thumb = R(ICON)
HTTP.CacheTime = CACHE_1HOUR
def Menu():
dir = MediaContainer(viewGroup="InfoList",title2=L('Episodes'), httpCookies=HTTP.GetCookiesForURL('http://www.youtube.com/'))
dir = FeedMenu(feed = FEED)
return dir
def FeedMenu(feed=’’):
dir = MediaContainer(viewGroup=“InfoList”,title2=L(‘Episodes’), httpCookies=HTTP.GetCookiesForURL(‘http://www.youtube.com/’))
if '?' in feed:
  feed = feed + '&alt=json'
else:
  feed = feed + '?alt=json'
rawfeed = JSON.ObjectFromURL(feed, encoding='utf-8',cacheTime=CACHE_1HOUR)
if rawfeed['feed'].has_key('entry'):
  for video in rawfeed['feed']['entry']:
    if video.has_key('yt$videoid'):
      video_id = video['yt$videoid']['$t']
    elif video['media$group'].has_key('media$player'):
      try:
        video_page = video['media$group']['media$player'][0]['url']
      except:
        video_page = video['media$group']['media$player']['url']
      video_id = re.search('v=([^&]+)', video_page).group(1)
    else:
      video_id = None
    title = video['title']['$t']
    if (video_id != None) and not(video.has_key('app$control')):
      try:
	    published = Datetime.ParseDate(video['published']['$t']).strftime('%a %b %d, %Y')
      except:
  	    published = Datetime.ParseDate(video['updated']['$t']).strftime('%a %b %d, %Y')
      if video.has_key('content') and video['content'].has_key('$t'):
	    summary = video['content']['$t']
      else:
	    summary = video['media$group']['media$description']['$t']
      duration = int(video['media$group']['yt$duration']['seconds']) * 1000
      try:
	    rating = float(video['gd$rating']['average']) * 2
      except:
	    rating = 0
      thumb = video['media$group']['media$thumbnail'][0]['url']
      dir.Append(Function(VideoItem(PlayVideo, title=title, subtitle=published, summary=summary, duration=duration, rating=rating, thumb=Function(Thumb, url=thumb)), video_id=video_id))
if len(dir) == 0:
  return MessageContainer(L('Error'), L('This query did not return any result'))
else:
  return dir
def Thumb(url):
try:
data = HTTP.Request(url, cacheTime=CACHE_1WEEK).content
return DataObject(data, ‘image/jpeg’)
except:
return Redirect(R(ICON))
def PlayVideo(sender, video_id):
yt_page = HTTP.Request(YOUTUBE_VIDEO_PAGE % (video_id), cacheTime=1).content
fmt_url_map = re.findall(’“url_encoded_fmt_stream_map”.+?"([^"]+)’, yt_page)[0]
fmt_url_map = fmt_url_map.replace(’/’, ‘/’).split(’,’)
fmts =
fmts_info = {}
for f in fmt_url_map:
map = {}
params = f.split(’\u0026’)
for p in params:
(name, value) = p.split(’=’)
map[name] = value
quality = str(map[‘itag’])
fmts_info[quality] = String.Unquote(map[‘url’])
fmts.append(quality)
index = YOUTUBE_VIDEO_FORMATS.index(Prefs[‘youtube_fmt’])
if YOUTUBE_FMT[index] in fmts:
fmt = YOUTUBE_FMT[index]
else:
for i in reversed( range(0, index+1) ):
if str(YOUTUBE_FMT*) in fmts:
fmt = YOUTUBE_FMT*
break
else:
fmt = 5
url = (fmts_info[str(fmt)]).decode(‘unicode_escape’)
Log(" VIDEO URL --> " + url)
return Redirect(url)
Ps I am also using the latest version of pms for plex home theatre and server if that helps at all?
Sent from my iPhone using Tapatalk
A couple of things to note ... the kickstarter is pretty out of date from what I can tell, so might not be the best starting place.  I'd try starting by looking at other working plugins.
Also things like this are not going to work (they are PHP)
Ok thank you I will give it a try with a working plugin thank you.
Sent from my iPhone 5 using Tapatalk
Hello Brian!
Based on a YouTube channel template I created a while back to quickly build some YouTube based channels I could quickly create a BFvsGF channel. I've attached it to this post.
The basic template code can be seen/forked/downloaded from here if you lke: https://github.com/sander1/basic-yt-user-channel.bundle
Thank you ill give it a try now :slight_smile:
Well would like to say thanks for the help guys I finally did it app works flawless on my tv made up some graphics to to with the prank channel on YouTube have a look
Awesome, glad it worked out for you ;)
