I am pretty sure I know the answer to this already, but wanted to ask just to be 100% sure.
Is it possible to use these custom style sheets in Safari or Chrome on an iPad?
@mjollymo said:
I am pretty sure I know the answer to this already, but wanted to ask just to be 100% sure.Is it possible to use these custom style sheets in Safari or Chrome on an iPad?
Not sure of any mobile userstyle plugins. Apparently Mozilla makes this possible if youâ're running Firefox on Android. Neither of which seem to fit your requirements.
addons.mozilla.org/en-US/android/addon/stylish/
While using the Plex Polished skin, when I change poster art, I have to refresh the page to be able to edit the poster again or even view the poster while onmouseover. When I mouse over a poster after changing the it, it looks like this (Inside Out).
Can you fix this? What part of the script is causing it? I can comment it out myself if I know what is doing it.
@chyron8472 said:
@wwwizzarrdryWhile using the Plex Polished skin, when I change poster art, I have to refresh the page to be able to edit the poster again or even view the poster while onmouseover. When I mouse over a poster after changing the it, it looks like this (Inside Out).
The code:
.MetadataPosterCard-cardContainer-2gRcQ:hover .MetadataPosterCardFace-face--dz_D {
box-shadow: none;
transform: scale(1.02)
is what is causing it. When I comment that out, that fixes it.
The code:
.MetadataPosterCard-cardContainer-2gRcQ:hover .MetadataPosterCardFace-face--dz_D { box-shadow: none; transform: scale(1.02)is what is causing it. When I comment that out, that fixes it.
Thatâs only supposed to appear when the metadata is loading. On my system, it flips around with the poster as soon as itâs done loading. Youâre using Chrome?
@wwwizzarrdry said:
The code:
Firefox. Yes, it flips and loads the new poster correctly when the poster is changed, but the box for the poster goes gray(transparent?) when hovered over with the mouse. When the mouse moves away, the poster appears again.
Plex Polished 4.0 is ready. It has been updated to target the new UNO UI.
I tried a couple tricks, but its easier said than done, at least with how I decided to get fullscreen images.
Tell me about it haha, I sat here trying things for at least a good hour or two and sadly could never come up with a complete solution.
I really wish the plex dev team would just stop making things so damn difficult to work with, or hell they should just bring back the old way of background images themselves so that we donât have to sit here and try and hack up various ways to do it.
The closest I came for at least messing with your theme (since I havenât even dived into updating my theme yet for UNOUI) is commenting out the
animation: move ease infinite !important;
animation-duration: 60s !important;
from div[class="PrePlayArtwork-imageContainer-3dXG6V CrossFadeImage-crossFade-10Sndv"] makes it so you canât scroll everything off the screen at least.
And adding a position: fixed !important; to the same div makes the issue disappear completely, but then a different issue arises to where when there is a page that you can scroll you can only scroll when you are moused over certain things.
Iâm sure we could find a solution eventually to remedy this problem.
FYI, you donât need to edit the css anymore to do that. All you need to do is select:
Ken Burns Effect: Off from the customization menu
Otherwise, that scroll container doesnât bother me enough to keep tweaking it. Let me know if you get it nailed down and I can push it.
Ah well Iâll remember that now xD Iâve been fiddling with it for a good day or so now and havenât figured out a way yet, Iâm about to a point where Iâm just going to say screw it and live with it even if it does irk me some. Devs will probably do something down the line again anyways thatâll change up how we have to do the background stuff again anyways.
Honestly this would be soo damn nice to have, but I donât see the plex devs ever doing something like this sadly ![]()
Yeah itâs a shame too. This idea of theming fits perfectly with the philosophy of user customization behind UNO.
FYI, they just implemented fullscreen background images over at https://app.plex.tv
