I am having trouble getting a post processing script to run correctly. Maybe someone has some words of advice or is seeing something I am missing. I simple want to get it to run and I will alter it after. My Plex server is running in a docker on Unraid. All the script currently does is creating a file. the script is below.
The script is located in a directory called content and is called from post processing setting using /content/test.sh
If I run the script outside of Plex and in the docker it runs fine and creates the file. However when it is run via post processing I get the following message in the log:
Mar 08, 2019 08:38:51.073 [0x1504acdce700] DEBUG - Job running: ‘/content/test.sh’ ‘/content/Recordings/.grab/81df13f5082cb869c9b9d9c061f5e3aecf574e1c/Carnival Eats (2014) - S03E02 - Lights and Literature.ts’
Mar 08, 2019 08:38:51.076 [0x1504acdce700] DEBUG - Jobs: Starting child process with pid 6587
Mar 08, 2019 08:38:51.126 [0x1504b51fc700] VERBOSE - DVR:Subscription: Not checking provider TIDAL, type not supported.
Mar 08, 2019 08:38:51.127 [0x1504b03f9700] VERBOSE - JobManager: child process with PID 6587 exited
Mar 08, 2019 08:38:51.127 [0x1504b03f9700] DEBUG - Jobs: ‘/content/test.sh’ exit code for process 6587 is 2 (failure)
Mar 08, 2019 08:38:51.127 [0x1504acdce700] ERROR - DVR:Recorder: Postprocessing script ‘/content/test.sh’ exited with error code 2.
PLEASE HELP!!!
#! /bin/bash
touch “testing”
Server Version#: 1.14.1.5488
Player Version#: 3.77.4
