When I add a pre-roll. I get the pre roll to play before for the movie just fine. But in the movie fails to play right after pre roll. Movie plays just fine if I remove pre rolls. Why? Please help.
Try retyping the path and also try another video if that doesn’t work. In the last 24 hours I found out about this features and couldn’t get it to work initially but I’ve gotten it working now. Along the way I ran into your same issue as I was trying out a number combinations. Make sure that there is NOT a comma or semi colon at the end of your last pre roll.
Thank you for the reply. I found the fix. It was actually on my client. On my Apple TV plex strings. I have to figure what chafe i made their to fix it. But it was on their.
