Plex/Proxmox/Debian Hardware Transcoding
Server Version#: 1.41.5.9522
Hello all,
I have a proxmox server set up with an lxc running plex. I have a nvidia 3060 that I want to use for HW acceleration. Plex is using the gpu for encoding, but not decoding. I have all of the nvidia drivers/cuda/nvidia-smi etc passed from the host. When I review the logs, it shows that it is using the gpu for encoding, but when I check nvidia-smi it shows no utilization which is strange.
How can I get gpu decoding working? I have attached my logs, I just turned off verbose before starting a recent transcode
Plex Media Server Logs_2025-03-20_22-37-19.zip (1.1 MB)
so these logs may potentially have some verbose entries so please accept my apoogies!
I’m not a proxmox expert or even regular user but have a working LXC which does HW transcoding.
The container was setup using the TTECK helper scripts
You should be able to tune it to your needs.
That’s actually what I started with, maybe I’ll try rebuilding the container from scratch with that
Here’s what it shows. Hopefully that helps
let me know what you need and how to get it.
I’ll gladly share
it appears the bundled ffmpeg doesnt have support for HEVC sources to be used with nvidia hardware. Does that seem correct? I do have HEVC enabled in my setting on plex
Yes, the FFMPEG bundled with PMS does support HEVC sources and encoding.
You MUST have hardware to support the HEVC encoding.
There is no software HEVC encoder.
I have a P2200 and RTX2000, HEVC has been supported for a long time (decoding) and HEVC encoding was recently added.
In transcoder Advanced settings, did you explicitly select the Nvidia (by name) ?
Are you passing the Nvidia runtimes into the LXC ?
I add /dev/dri and then the runtime
# Add it (Both Intel and Nvidia)
lxc config device add "$1" GPUs gpu gid=$Gid
# Add Nvidia runtime
lxc config set "$1" nvidia.driver.capabilities all
lxc config set "$1" nvidia.require.cuda true
lxc config set "$1" nvidia.runtime true
I can see the card from the lxc when I run nvidia-smi, and I think I have all the settings enabled in plex. Thats why I am leaning towards a plex issue rather than proxmox issue.
the logs indicate it is using nvenc for encoding but doesnt use nvdec for decoding
