Plex randomly won't add downloaded media
I’m having a weird issue with Plex. I have Sonarr setup to automatically download my TV shows, which are then synced to gdrive using rclone. I have a weird issue with Plex that’s causing plex to randomly not add new media files to the library. Sometimes the file will add successfully the first time, or I can get plex to add them properly if I do one of two things: 1. Move the media file out of the folder, then move it back in and rescan my library manually. 2. Delete the media file and redownload it.
Either solution above ALWAYS works to fix it for that particular instance, however that is not a good fix.
Plex logs are not very telling…
These are the Scanner logs on an attempt where the media is not added: https://pastebin.com/NnRtpr2i
These are the logs from a successful attempt after moving or deleting the first bad one: https://pastebin.com/ir0eRXWG
The show in question in the above logs is “/home/alex/rclone/gmedia/TV/Shameless (US)/Specials/Shameless (US) - S00E03 - Hall Of Shame - Ian & Mickey - Daddy Issues WEBDL-1080p.mkv”
Any idea’s?
Server Version#: 4.49.2
Player Version#: Web Player 4.49.2 / Any Player
See logs in pastebin links.
