So my shows will record but all of the sudden they are getting stuck at 100 percent, but they do not get processed and moved to the tv show folder. Anyone else have this issue or know how to maybe fix it?
well just updated to 1.81 and it is working again, fingers crossed!
The fix isn’t sticking. I’m having the same issue with the stuck completed recordings with no transcoder on the Shield TV. It doesn’t seem to happen on certain channels but does on others. Seems to be pretty consistent with only getting stuck on some of the channels. Any ideas on fixing this yet?
Have you got transcoding switched on?
I assume your still having problems. The DVR recording where it segments and recombine recording at the end has lots of problems, this is one along with corrupt recordings.
I’m having the same issue where it is sticking at 100 percent complete. The only way I can get it to stop is reboot my Synology NAS. I’ve tried it with and without encoding. Same problem. I’m running version 1.14.1.5488.
