Plex Remote access on DS918+
I have been trying to work out how to remote access plex with my server on a Nas DS918+.
I have opened the ports on my router and on the Nas but still no luck.
Not sure what I am doing wrong and need help to get it working.
You’re running FreeNAS on your Synology?
No I am not.
FYI, you tagged your post as “server-freenas.” Correct tagging will get your post in front of the right eyes.
  1. Does canyouseeme.org show the server is available? Status on the Plex Remote Access config page is not reliable.
  2. Provide a screenshot of the port forwarding rule in your router. The only port needed for remote access is TCP/32400. You can remap it to an alternate external port if desired.
  3. Provide a screenshot of the Remote Access settings for your PMS. Block out any public address if displayed. Check Manually specify... Leave the port at 32400. Perform any remapping on your router.
Port forwarding rule in my Asus router:
PMS Remote Access config page says it is not working.
It is still working (a remote user was streaming an hour ago):
Screenshot (344)
