Plex Remote Access on Netgear Orbi only indirect connection
Server Version#: Version 1.18.1.1973
Player Version#: Web or Newest Android APP
Isp provided Modem/Router: Alcatel-Lucent G-241W-P
Router: Netgear Orbi RBR50
So I dont usually do this but this time im really at a loss for whats going on.
The problem is that whatever I do, I am only able to get an indirect connection to my PMS, I have tried both with manuel port forwarding, and with the UPnP-NAT. I can see on my Orbi panel that my PMS creaters a UPnP rule just fine and I am able to successfully ping it with canyouseeme.org/. The same is true with port forwarding, where I can also see the port open, but when I connect remotely though cellular on my phone it still pops up as indirect connection. Somehow I can play on full quallity on the Android app but on internet sharing with a pc it confines it to the 1 mps transcoded stream. This is from same external IP through tethering my phone to my laptop. I have my stuff setup as kind of a double NAT as my gateway is also a Router, though that Router dosen’t support Bridgemode, so I have my Orbi Router setup in DMZ hosting mode on my Modem/Router, and turned off all NAT ALG servies and turned off UPnP on my Modem Router.
I have Looked on a lot of people having simmilar issues and trying them out but nothing has worked so far, I’ve also changed my Orbi’s DNS to cloudflare 1.1.1.1, to see if that would help because I saw something simmilar on another Thread. Does anyone know why it isen’t working or any Idea of what I could try?
Edit: It seems like the Issue has solved itself for now? I didnt change anything but waiting apparently fixed the Issue.
This topic was automatically closed after 90 days. New replies are no longer allowed.
