Plex restarting multiple times on Firestick
Plex has been getting progressively worse in recent days with multiple restarting when watching Movies and TV via Firestick devices. Is this a known issue at present?
I have had this issue for a long time. Not only restarting multiple times yet also crashing when trying to start Plex on my Firestick. I had to roll back to Plex version 8.13.2.23227 Which is the latest and the only version that seems to work on my firestick without crashing and etc. I tried all newer versions from their on out and the version above is the only one that works for me.
Can you get the android logs after it happens
I too have had this problem and it is getting to the point I am looking for another application to use. Is rolling back the only solution and are there just a few of us with this issue?
Does plex freeze/hang then restart itself? thats what mines has been doing for weeks but I’ve found it very hard to try and capture it as it appears to be random, it’s happening on multiple firestick devices in my home and out of my home, once it crashes or restarts, I can play the same file without any issues.
Anyway, I spent today with the network log enable in plex on my FTV and tried to capture when it occured.
In the event that my issue is releated to there issue, I have my firestick and server logs available, if not then I’m happy to create a new post.
FTV plex version 8.22.0.27533 (bdaff3f3)
Server Version: 1.24.2.4973
ftv-plex-8.22.0.27533 (bdaff3f3).log (226.4 KB)
com.plexapp.system.log (22.4 KB)
