I have a file called Time Traveling Bong - S01E01E02E03 - Chapter 1 The Beginning & Chapter 2 The Middle & Chapter 3 The End 1080p WEB-DL but only episode 1 and 2 are shown in Plex. From what I’ve read in the naming guide this should be fine.
I think it should be S01E01-E03
@OmgImAlexis said:
I have a file calledTime Traveling Bong - S01E01E02E03 - Chapter 1 The Beginning & Chapter 2 The Middle & Chapter 3 The End 1080p WEB-DLbut only episode 1 and 2 are shown in Plex. From what I’ve read in the naming guide this should be fine.
no, this is not correct:
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
use S01E01-E03
@OttoKerner said:
@OmgImAlexis said:
I have a file calledTime Traveling Bong - S01E01E02E03 - Chapter 1 The Beginning & Chapter 2 The Middle & Chapter 3 The End 1080p WEB-DLbut only episode 1 and 2 are shown in Plex. From what I’ve read in the naming guide this should be fine.no, this is not correct:
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Showsuse
S01E01-E03
How come S01E01E02 works but more than 2 doesn’t?
Seems a bit weird to cap it at only 2 episodes.
I can’t tell you that.
Your naming convention was never meant to work, so if it did anyway, its behaviour doesn’t follow any rules or logic
