Plex Server does not open on PC
Hello,
I would really appreciate some help. I have used a Plex media server before and it worked very well. Basically, I have had to create a new account and after re-subscribing, re-loading and basically going through the entire process again with a new account, the server will not open on my PC.
I assume there is something left over from the previous account that is causing problems but I have tried to delete all trace of Plex from my PC prior to reloading this. However, I am having no luck.
Any help would be really appreciated. I have Windows 10, my PC is connected through LAN to my Samsung Smart TV, and I have spent quite some days trying to find a solution. I’m not terribly tech savvy but I think I know just about enough to make this work. It seems bizarre that the app would simply stop booting up - not even an error message or instructions for removal of stealthily hidden files. Just does nothing!
Thank you in advance,
Seamus
Here is the procedure to remove every little trace of the previous install: https://support.plex.tv/articles/201941078-uninstall-plex-media-server/
Thank you Otto - that worked perfectly and you have managed to bring back my sanity! Thank you and best of luck to you too.
