Plex Server doesn't work after PC standy
Server Version#: last version
Player Version#: app on LG
Hi, I’ve a problem with Plex Server running on my Windows machine.
When I stand by the PC, once I re-run, on the app on my TV it seems all media files are not accessible.
I Need to exit from the app, restart Plex Server (close and reopen) and than restart the app on TV.
How can I fix It? Common problem?
As a server Plex is meant to be always running, a client trying to pull files will not wake it up.
First would be to uncheck “Empty trash automatically after every scan” under server settings >Library.
If the media files are on a NAS that would also add to the complication. Depending on you usage you could switch to a low power NUC that can stay on.
Wait, I didnt try to wake up from client. When I access from client, the PC has been reloaded (accessing to Windows and so on, than open the lg app later).
Any clues anyone?
Really no one can help me?
When the unit goes to sleep, can you access it via the web browser? If not can you post your server logs after a resume but before you restart it?
