Server Version#:1.15.3.876-ad6e39743
I would like to ask for their help. According to service plexmediaserver status , Plex is running.
root@omv:~# service plexmediaserver status
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor
preset: enabled)
Active: active (running) since Mon 2019-04-08 19:08:00 CEST; 19min
ago
Process: 1079 ExecStartPre=/bin/sh -c /usr/bin/test -d “{PLEX_MEDIA_SERVER_AP
PLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPPOR
T_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 1085 (sh)
Tasks: 76 (limit: 4915)
CGroup: /system.slice/plexmediaserver.service
├─1085 /bin/sh -c PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/
os-release | awk -F= "{print \$2}" | tr -d \" )" PLEX_MEDIA_SERVER_INFO_DEVICE=
"PC" PLEX_MEDIA_SERVER_INFO_MODEL="(uname -m)" PLEX_MEDIA_SERVER_INFO_PLATFOR
M_VERSION="$(grep ^VERSION= /etc/os-release | awk -F= “{print $2}” | tr -d " )
" LD_LIBRARY_PATH=/usr/lib/plexmediaserver/lib “/usr/lib/plexmediaserver/Plex
Media Server”
├─1114 /usr/lib/plexmediaserver/Plex Media Server
├─1271 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Res
ources/Plug-ins-ad6e39743/Framework.bundle/Contents/Resources/Versions/2/Python/
bootstrap.py --server-version 1.15.3.876-ad6e39743 /usr/lib/plexmediaserver/Reso
urces/Plug-ins-ad6e39743/System.bundle
├─1317 /usr/lib/plexmediaserver/Plex DLNA Server
├─1320 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmedia
server/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1
.15.3.876-ad6e39743 32600 /waitmutex
└─1362 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserve
r/Resources/Plug-ins-ad6e39743/Framework.bundle/Contents/Resources/Versions/2/Py
thon/bootstrap.py --server-version 1.15.3.876-ad6e39743 /usr/lib/plexmediaserver
/Resources/Plug-ins-ad6e39743/PlexMovie.bundle
ápr 08 19:08:00 omv systemd[1]: Starting Plex Media Server…
ápr 08 19:08:00 omv systemd[1]: Started Plex Media Server.
When I go to http://10.0.30.222:32400/web/index.html , it says it’s unavailable.
The check shows the following sudo journalctl -xe | grep -i plex
root@omv:~# sudo journalctl -xe | grep -i plex
ápr 08 19:07:59 omv systemd[1]: Mounting Mount shared folder plex to /sharedfolders/plex…
– Subject: Unit sharedfolders-plex.mount has begun start-up
– Unit sharedfolders-plex.mount has begun starting up.
ápr 08 19:07:59 omv systemd[1]: Mounted Mount shared folder plex to /sharedfolders/plex.
– Subject: Unit sharedfolders-plex.mount has finished start-up
– Unit sharedfolders-plex.mount has finished starting up.
– Subject: Unit plexmediaserver.service has begun start-up
– Unit plexmediaserver.service has begun starting up.
– Subject: Unit plexmediaserver.service has finished start-up
– Unit plexmediaserver.service has finished starting up.
ápr 08 19:08:03 omv kernel: e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Please help me fix the problem.
