Plex server keeps crashing over and over
Server Version#: 1.24.1.4931-1a38e63c6
Player Version#: n/a
Linux version: Ubuntu 16.04.7 LTS
Plex keeps constantly crashing as people are trying to play files. I left it overnight (when no one was playing anything) and it stayed up the entire night. Now that it’s morning and people are trying to play things again it starts to crash. This only started happening the last couple of days and has never happened before. This happens when people try to play things from directly connecting in the browser, or from a web browser through the plex website.
I tried fixing this by updating to the latest version manually
I have attached all the log files and crash dumps. I’m not really sure what the exact cause of the crashes are though (from 1.24.0.4930-ab6e1a058 to 1.24.1.4931-1a38e63c6) but the exact same thing keeps happening
Most recent time of crash in the logs: 2021-08-22 10:27:48
plexcrash.zip (9.8 MB)
The most recent “Plex Media Server.log” file shows this:
Aug 22, 2021 10:27:04.281 [0x7f779f349b38] INFO - Plex Media Server v1.24.1.4931-1a38e63c6 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT 12:00
Aug 22, 2021 10:27:04.282 [0x7f779f349b38] INFO - Linux version: 16.04.7 LTS (Xenial Xerus), language: en-US
Aug 22, 2021 10:27:04.282 [0x7f779f349b38] INFO - Processor Intel(R) Xeon(R) CPU           E5520  @ 2.27GHz
Aug 22, 2021 10:27:04.282 [0x7f779f349b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Aug 22, 2021 10:27:04.282 [0x7f779f349b38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Aug 22, 2021 10:27:04.607 [0x7f779cc70b38] WARN - Couldn't determine bundle identifier for plug-in at: "/usr/lib/plexmediaserver/Resources/Plug-ins-1a38e63c6/WebClient.bundle"
Aug 22, 2021 10:27:06.033 [0x7f779d0cbb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Aug 22, 2021 10:27:06.033 [0x7f779d0cbb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Aug 22, 2021 10:27:06.037 [0x7f779ce4bb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Aug 22, 2021 10:27:06.037 [0x7f779ce4bb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Aug 22, 2021 10:27:06.278 [0x7f779c819b38] WARN - Crash: Crash reporting disabled
Aug 22, 2021 10:27:08.123 [0x7f779cc70b38] INFO - Refreshing paths watched by LibraryUpdateManager
Aug 22, 2021 10:27:08.735 [0x7f779c383b38] WARN - Held transaction for too long (../Library/MetadataCollection.cpp:500): 0.570000 seconds
Aug 22, 2021 10:27:10.120 [0x7f779d07bb38] WARN - [EventSourceClient/pubsub] MyPlex: attempted a reachability check but we're not yet mapped.
Aug 22, 2021 10:27:10.991 [0x7f779c5d8b38] INFO - Sync: downloaded 3 sync list(s) with 10 sync items(s): 0 new, 0 updated, 0 deleted
Aug 22, 2021 10:27:10.991 [0x7f779eac0b38] WARN - Sync: local sync directory "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+" does not exist
Aug 22, 2021 10:27:20.481 [0x7f779c2edb38] INFO - [PlexRelay] Allocated port 22279 for remote forward to 127.0.0.1:32401
Aug 22, 2021 10:27:20.570 [0x7f779c33cb38] INFO - [PlexRelay] Allocated port 9141 for remote forward to 127.0.0.1:32401
Aug 22, 2021 10:27:31.609 [0x7f779d07bb38] ERROR - [CERT/OCSP] Error opening file '"/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/OCSP/main.der"' - No such file or directory (2)
Aug 22, 2021 10:27:31.919 [0x7f779c7f6b38] INFO - [CERT/OCSP] Successfully retrieved response.
Aug 22, 2021 10:27:32.690 [0x7f779c78db38] WARN - NAT: PMP, timed out waiting for response.
Aug 22, 2021 10:27:35.692 [0x7f779c78db38] ERROR - Error issuing curl_easy_perform(handle): 28
Aug 22, 2021 10:27:40.024 [0x7f779c6f0b38] INFO - AutoUpdate: no updates available
Aug 22, 2021 10:27:42.050 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:42.050 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.479 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'sectionID' found, ignoring.
Aug 22, 2021 10:27:43.479 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.479 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779c6f0b38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779be75b38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779c6f0b38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:43.480 [0x7f779be75b38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.433 [0x7f779accdb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.433 [0x7f779accdb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.506 [0x7f779accdb38] WARN - SLOW QUERY: It took 390.000000 ms to retrieve 50 items.
Aug 22, 2021 10:27:44.685 [0x7f779a6f6b38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.685 [0x7f779a6f6b38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.690 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.690 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.690 [0x7f779abcbb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.690 [0x7f779abcbb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.801 [0x7f779accdb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.801 [0x7f779accdb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.811 [0x7f779ae4db38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.811 [0x7f779ae4db38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.883 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'sectionID' found, ignoring.
Aug 22, 2021 10:27:44.883 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.883 [0x7f779c6bdb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.937 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.937 [0x7f779c69ab38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:44.954 [0x7f779c6bdb38] WARN - SLOW QUERY: It took 430.000000 ms to retrieve 50 items.
Aug 22, 2021 10:27:45.002 [0x7f779a77ab38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.002 [0x7f779a77ab38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.275 [0x7f779c6f0b38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.275 [0x7f779c6f0b38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.283 [0x7f779c33cb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.284 [0x7f779c33cb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.323 [0x7f779c33cb38] WARN - SLOW QUERY: It took 290.000000 ms to retrieve 63 items.
Aug 22, 2021 10:27:45.354 [0x7f779c6f0b38] WARN - SLOW QUERY: It took 260.000000 ms to retrieve 63 items.
Aug 22, 2021 10:27:45.688 [0x7f779be75b38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.688 [0x7f779be75b38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.744 [0x7f779abcbb38] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:45.744 [0x7f779abcbb38] WARN - QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Aug 22, 2021 10:27:46.817 [0x7f779a77ab38] ERROR - Unknown metadata type: folder
Aug 22, 2021 10:27:46.822 [0x7f779abcbb38] ERROR - Unknown metadata type: folder
Aug 22, 2021 10:27:48.598 [0x7f779c33cb38] WARN - [Transcode] Crash: Crash reporting disabled
I got it to crash again this time with DEBUG level logs enabled:
Crash happened at 2021-08-22 11:01:54
crash_2021-08-22_110154_debug.zip (345.6 KB)
I disabled the following two settings and it seems to now work:
  • Use hardware acceleration when available
  • Use hardware-accelerated video encoding
I do not have a GPU in the system, but for some reason these are what was causing the crashing (as far as I can tell)
PMS will always probe for VAAPI and Nvidia unless told otherwise.
Given your Nehalem doesn’t have QSV capability, it will fail on that probe
then move on looking for more.
That as foundation,
  1. Which Nvidia card do you have installed ?
  2. Which Nvidia drivers do you have installed?
Lastly, it doesn’t hurt to check what /dev/dri shows us.
It should be showing us only 1 renderDxxx device – the Nvidia
With your next post, also please include the Codec type and SDR/HDR status of the video being played which faults it.
