Server Version#:1.43.2.10687
Player Version#:4.159.0
I did a search to see if I could find an answer before posting but everything I found did not work. I recently had to send my Synology DS2415+ out for maintenance/upgrades (now has 16GB of ram) and had to add another volume to my server because I went beyond the maximum 109GB. Ever since I have done this PLEX has become unreliable/unstable. All of my libraries (except for 3) are in the same volume as the program. It seems as soon as there is any kind of a load on the PLEX it just shuts off. It doesn’t matter if its getting new/updating metadata, scanning folders or any of the other common things it used to do without a problem. I upgraded to the latest server version when I put it back into service. I did make the mistake of deleting the old source folder when I was reassigning new folders in the volume so I know that is causing some of my metadata issues and it will just take time for ti all to right itself. I turned off all of the settings that cause additional load, such as generating video and credit markers, generate voice activity data. I do not have any audio files in my library. I am also not having anything transcoded. I also noticed that some folders it does not sense that files have been added and even after forcing a scan the new files that have been added are not sensed, this is volume agnostic. I know it is not my naming convention as I have been using this for a long time and know how to name bot TV and movies. Here is an example of both:
Mountain Men S01E01 - Winter Is Coming
Crime 101 (2026)
What am I missing? I travel a lot and rely on my PLEX when I am traveling. But right now I cannot rely on it.
Ensure Plex is configured for debug server logs (default).
After the problem reoccurs:
1 Restart Plex Media Server
2 Wait three minutes to capture the startup sequence
3 Pull server logs.
4 Post the zip file to the thread.
I knew I had forgotten something. Sorry about that here they are.
Plex Media Server Logs_2026-07-06_22-06-07.zip (3.6 MB)
Thanks for the log files.
You’ve exceeded the number of folders that the Synology can monitor. This is very common on Synology NAS (it appears in the Plex log files as an out of space error).
This may not be the cause of Plex crashing, but it needs to be addressed (fix the obvious stuff first).
Follow Synology FAQ 16: Increase the number of folders Plex can monitor.
You must reboot the NAS after running the FAQ, as this is a change to the Synology OS, not to Plex.
Also, you will have to re-run the FAQ after Synology OS updates such as updating from 7.1.1 to a more recent release such as 7.2 - 7.4.
If Plex crashes after running the FAQ, restart Plex, wait three minutes, then pull & post a new set of log files.
From Plex Media Server.1.log:
Jul 06, 2026 20:09:14.144 [140208383703864] ERROR - [Notify] Failed to add watch for "/volume2/TV/Loki/Subs" (28: No space left on device)
Jul 06, 2026 20:09:14.144 [140208383703864] ERROR - [Notify] Failed to add watch for "/volume2/TV/Loki/Subs/Loki.S01E01.WEBRip.x264-ION10[eztv.re]" (28: No space left on device)
Jul 06, 2026 20:09:14.145 [140208383703864] ERROR - [Notify] Failed to add watch for "/volume2/TV/Loki/Subs/Loki.S01E02.WEBRip.x264-ION10[eztv.re]" (28: No space left on device)
Jul 06, 2026 20:09:14.145 [140208383703864] ERROR - [Notify] Failed to add watch for "/volume2/TV/Loki/Subs/Loki.S01E03.WEBRip.x264-ION10[eztv.re]" (28: No space left on device)
I have all of my movies in alphabetical folders (0-9, and A-Z) would it be better to start with putting all of them in one folder to see what happens? That would reduce the number of folders immediately. I do the same with my TV shows and all of my other sub folders. Should they all just be in one giant folder to reduce the number of folders that it has to monitor?
Even if those things dropped the NAS below the limit, they’re just postponing things.
Run the FAQ.
I had to with my DS918+. Best to fix, rather than avoid, the problem.
Ok i just ran the script. I will see how it does in the next day or two. I will stress it here in a little while to see if I can get it to crash like it did previously.
Well that lasted less than 20 minutes. All I did was ask it to scan library files. I do not know how far it got before it crashed. I asked it to scan when I waked off to eat and when I came back it was not running anymore. Here are the updated logs after I ran the script to increase the number of folders it can monitor, restarting the server and scanning the library. I allowed it to run for a little over three minutes before I pulled this set of logs.
Plex Media Server Logs_2026-07-08_18-51-53.zip (3.7 MB)
If I were to investigate my logs what would I be looking for? I am new to this and do not know what an indicator of a problem is.
After expanding my library and restarting PLEX still continues to crash. It crashed during the night at some point. Here is a fresh set of logs. Hopefully someone can point me in the right direction on how to fix this problem. I also posted in the Synology forums and the only response I received there was to post post here with my logs.
I looked but did not find it is there a thread somewhere that teaches us how to read our logs?
Plex Media Server Logs_2026-07-11_09-25-50.zip (4.2 MB)
No one from PLEX support can help me with this?
The next beta version has a fix for what I think is your issue.
I can send you a link to a preview release of this so you can test it. Hoping to have that by today or tomorrow.
OK I am open to trying it but I have never used a beta version. If it causes problems will I be able to revert back tot he previous version?
To revert back to an earlier version, you must have the .spk file for the previous version of Plex.
- Open Package Center
- Stop Plex from running
- Uninstall Plex. Choose the first option, uninstall only, keep all files (DSM 7).
- Install the previous version by clicking on Manual Install (upper right side of the Package Center window) and select the previous .spk file.
I’ve DM’d you a link to the pre-release build.
I am having this exact same issue, and it just started happening in the last couple of days.
