Server Version#: 1.19.1.2701
I just built a new pi system. I installed plex and it keeps crashing at startup. I cant find any log information that is useful. not sure where to start. if I had useful log info I could probably figure this out. Any ideas?
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Tue 2020-04-28 16:28:59 CDT; 4min 13s ago
Process: 823 ExecStartPre=/bin/sh -c /usr/bin/test -d “{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Process: 830 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; export PLEX_MEDIA_SERVER_INFO_MODEL="(uname -m
Main PID: 830 (code=killed, signal=ABRT)
Apr 28 16:28:59 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Apr 28 16:28:59 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Apr 28 16:28:59 raspberrypi systemd[1]: Stopped Plex Media Server.
Apr 28 16:28:59 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Apr 28 16:28:59 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
Apr 28 16:28:59 raspberrypi systemd[1]: Failed to start Plex Media Server.
this is all the log contains
Plex Media Server.log
Apr 28, 2020 16:28:54.263 [0x73a28450] INFO - Plex Media Server v1.19.1.2701-6327e27bf - Raspbian GNU/Linux PC armv7l - build: linux-armv7hf_neon debian - GMT -05:00
Apr 28, 2020 16:28:54.267 [0x73a28450] INFO - Linux version: 10 (buster), language: en-US
Apr 28, 2020 16:28:54.267 [0x73a28450] INFO - Processor Arm
Apr 28, 2020 16:28:54.267 [0x73a28450] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 28, 2020 16:28:54.273 [0x76fdc920] DEBUG - BPQ: [Idle] -> [Starting]
Apr 28, 2020 16:28:54.273 [0x76fdc920] VERBOSE - BPQ: delaying processing 120 second(s)
Apr 28, 2020 16:28:54.462 [0x76fdc920] DEBUG - Job running: ‘/usr/lib/plexmediaserver/CrashUploader’ '–directory=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cras$
