On Plex Server (Synology DS-3615xs) the playback does not start and gets stuck on playback spinner for ever. Troubleshooting done, with PMS restart after each action, with no success:
Update to latest PMS ( 1.19.2.2737)
Tried Smart-TV and Web-player
Configure manually the transcoding directory to /volume1/Plex/tmp_transcoding/ (long time ago this worked and solved the “no-playback-starting” problem. Not this time…)
Clean-up the codecs (.so files from /volume1/Plex/Library/Application Support/Plex Media Server/Codecs/99c90e0-3095-linux-x86_64 removed for PMS to fetch them anew)
After may tried and PMS restart no luck! Logs are attached.
So, problem SOLVED and thank-you go to @trumpy81 for pointing to the right directions to look into! Some troubleshooting details for any future reference:
Network Adapters: I use a 10Gbit Intel network card and all Synology network adapters (4) were disconnected (i.e. no physical connection, although in the CP you can see the last configured IP address for each one, which cannot be removed). Strangely, it seems that PMS keeps remembering older used IP address (…probably to try them out in case of no connectivity?). Followed the suggestion of @trumpy81 to deactivate IPv6 plus configured network on my primary adapter (port-1 of 10Gbit Intel card)
User rights: confirmed “plex” user had full (admin) rights on temp trans-coding folder
Trans-coding: …tough to have been a faulty/failing disk since no health issue was reported by Synology on both Volume and Disk level, running also on RAID-6. However, I gave it a try and switched trans-coding temp location from volume1 to volume2. Strangely, seeing the console logs, Plex continued trying to trans-code to volume1, even after service restart!
After every single (1) change PMS was restarted but all these produced no results. ONLY after making a full server restart (reboot) trans-coding came back to life! Then, changed back trans-coding temp folder to default (i.e. no location path manually defined) and transcoding was again on-line.
Bottom-line, it seems that for some reason PMS got some network hick-ups that were rectified by deactivating IPv6 and/or defining a specif network interface as preferred.
Sadly the Network parameters trimming provided a resolution only shortly.
I was getting quite many “EAE timeout! EAE not running, or wrong folder?” errors (console view) and looked it up. I have quite a few, and then some, folders of movies/tv-series/etc, thus I am now giving it a try with “Increase the number of directories Linux can monitor (Notify)” by adding fs.inotify.max_user_watches=262144 in the /etc/sysctl.conf.
I guess, as @trumpy81 has rightly pointed out, there are quite a few different issues underlying here. I am not sure that increasing the number of monitored directories did much however I have set it to fs.inotify.max_user_watches=65535 since I have 35K+ folders.
On the Network aspect, Synology DS-3615xs has 4 Ethernet adapters plus i have a 10Gbit SFP+ card with 2 more. The four (4) default Ethernet adapters of Synology are deactivated (i.e. no cable connected, with internally assigned IP: 169.254.x.x) but is really strange that PMS is still browsing on ALL six (6) of them, including the Four (4) deactivated ones! Why so?!
Even more strange is that when PMS is active (i.e. streaming content) there are few warnings/errors BUT when PMS is idle there is a flood (e.g. “Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1”, browsing the deactivated Ethernet ports, etc). Possibly that’s why either:
PMS gets eventually stuck on about 12% CPU usage (on idle!) OR
Trans-coding functionality ceases and when trying to playback something it gets stuck on playback spinner?)
NAT: PMP, got an error: Not Supported by gateway.
On Synology, this isn’t how we increase the number of directories PMS can monitor. We used to do that but Synology didn’t like us changing it so they obfuscated it.
HOWEVER
It’s best to verify we need to increase the table prior to just asserting a new size.
Are there “No space left on device” errors while Notify is initializing ?
If we do need increase, we need to do it this way
Then restart DSM.
Per the CPU stuck, I’d like to see some logs please; DEBUG logs ZIP; gathered about 2 minutes after PMS starts and having sat as idle as possible during that time.
Thank you for the feedback @ChuckPa! With an idle PMS service, the service process goes up to even 80-90% CPU usage, and I run a DS-3615xs on an upgraded CPU (Xeon E3-1285L v3 3.1GHz) and RAM (16GB).
The folders table increase is a must since there is a flood of such errors: [Notify] Failed to add watch for “/volume2/Videos/TV Series/xxxxxxxxxxx” (28: No space left on device)
I will give it a try, with the right Syno-way this time, and get back.
No luck with changing the folders table. Meaning I did the math as per Synology FAQ for my folders (45K) and started with s2s_watches_max=65,536. Still i was getting (in console) a flood of Notify alerts and started making gradual increments up to 2,147,483,648. Synology was emailing me every time the task was running successfully and was also restarted after every change. Still, Notify alerts persist!
@ChuckPa PMS is always starting properly, is accessible and responsive via Web-UI BUT the problem is that is does not start payback (trans-coding), even after full server reboot, and that sometimes, in-time (hours/days), the process itself might get stuck. When this happens, the CPU is stuck on a 12-14% load (as if PMS is streaming normally, although it doesn’t) or at worst the CPU load is gradually increasing to almost max-out the CPU (even up to 90%). In the previous post you may find the logs retrieved via PMS web interface after a full server reboot and for a few minutes with the PMS idle (no streaming, not even web access to UI). I hope you might dig out something!
Regarding the latest procedure to retrieve the logs manually, I will leave PMS aside to eventually get into the no-reason-CPU-load status and get you the logs. Thanks.
@ChuckPa here we go, PMS is on 12% CPU usage, supposedly as trans-coding, although it is idle with no clients connecting or performing any other user task (folders scan, etc)
@ChuckPa I have raised this point earlier, why is it that PMS is trying to communicate with via IP address which is not valid? I had PMS installed and running on Synology under 192.168.123.2 but long time ago i moved to 10Gbit adapter with other IP (192.168.123.12) and any older IPs used are not valid (i.e. adapters have no electrical connection to the LAN). Why is PMS still trying to have any communication via a disconnected port and not active IP?
Added on my Mikrotik
Video station was never installed/used on my Syno.
Going to reboot and will monitor and report here. Thanks
@ChuckPa After the reboot the trans-coding starts properly but let’s see if it will crush later on…
I Did the DNS rebind to allow PMS IP address (192.168.123.12) BUT PMS is still trying to get communication on the non-existing 192.168.123.2! (the primary IP used when I installed PMS some years ago)
ERROR via console: “getaddrinfo(192-168-123-2.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -3”
Why so? How can we get PMs to “forget” older IPs? (of course, I have the proper IP 192.168.123.12 selected as “Preferred network interface” on PMS)
It’s possible to get unused (unplugged) adapters to come up with inactive IP addresses
plug in a wire
Set to DHCP
Let it pull an IP
Un-plug the wire
Complete for other adapters
Restart DSM
When restarted
Verify DSM has the 1 active adapter checked as the Default Gateway
Go to PMS (Settings - Server - Network - Show Advanced)
Select the same preferred adapter.
For future reference.
Placing two adapters on the same subnet is not wise. It confuses PMS because DSM uses the two adapters interchangeably and indiscriminately . Extreme care, executed at the command line level, must be used in such cases.
So far so good! It seems that no hic-ups on trans-coding since i configured this.
I am not sure what is the DNS resolver but DNS resolution on my Mikrotik is configured to external DNS (not on LAN) using three WAN DNSs (primary, secondary, tertiary)
I have only two (2) eth-ports active (one 10Gbit expansion card on synology) and they are on different class-C networks. One is the primary one that goes to the managed switch (WAN access) and the other is only to connect with a 2nd Synology (backups).
By inactive IP do you mean 169.254.x.x? I have done the DHCP trick (without an electrical connection) but i still see PMS reporting these “inactive IPs”. I will check it again
Any idea why I am still getting these Notify alerts? Despite pushing the folders table size to the roof?!
Yes, I used the Synology FAQ article you had sent me and I had restarted after every incremental change but still getting Notify errors. I have about 45K folder. Shall i stick to s2s_watches_max=65536 ? Maybe better to deactivate the DB monitoring (I don;t mind to do manual updates when i add content)
Still getting continuously “Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1”
You mentioned reinstalling DSM. I would mind making a fresh install IF I don’t lose the content and the PMS DB (edits done, watched status, etc). Is this feasible?
