Plex Sharing - Label Filtering Only Works for 1 Library
I was going to share out a couple of movies with a friend but didn’t want them to have access to EVERYTHING. I created a sharing label for “MCU” and applied it to the appropriate movies. Now I have “MCU” movies across 2 different libraries which are based on quality (low quality vs regular content). The “MCU” labeled movies appear in the low quality library but nothing appears in the other library at all. I’ve confirmed that all movies are using the same label.
Am I missing something?
edit
To add all of the movies appear on the home screen under “Recently added movies” and are playable from there. They just do not appear under the normal library.
Doing some more testing. If the filter is set to All, by Movies, By Title nothing appears. Change any one of these and the movies appear. It’s very odd.
