Plex still failing on Formuler Z8 (Android) Player
Hello
This problem started about a month ago with, I believe, Version 9.1.5. I was hoping that with the latest update (9.2.0) the issues experienced previously would have been resolved but unfortunately not.
A brief description of the problem:
Navigating around the App (i.e. left right up down) is fine.
However, if I single click on the OK button (effectively to select some media to play) then Plex falls down and the “Plex has Stopped” pop up comes up.
If I long click on the OK button, this brings up the sub-menu and I can select “Play” from the sub-menu and the media plays (so I have a work around, but not efficient).
Unfortunately I cannot send you any log files as I am unable to enter the Settings menu (as it requires a single click the OK button to select it).
I’d be grateful if anyone has any ideas.
I believe that @Iceman1569 @Bullach @ghousheh82 and @PLEX_LATINO have also had problems recently with the Android player. [Apologies if you are not experiencing the same problems but thought you might be interested if you are].
I still have the problem with 9.2
