Unraid plex docker -
Server Version#: 6.8.3
Player Version#: 1.20.1.3252
Upgraded to a second CACHE drive on my UNRAID server and now I am getting the following error in PLEX:
“Playback Error. An error occurred loading items to play.”
This is media that has worked in the past without any issue and new media that recently was added doesn’t work at all. The media exists in the Media folder that has been the same since I built my unraid server and setup plex so I am unsure what the issue is. Possibly a corrupt database? The following is my logs from the docker container. If there is something else that would be useful, let me know where it is and ill post it up.
s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Connection to 172.104.96.77 closed by remote host.
Stopping Plex Media Server.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
Critical: libusb_init failed
s6-svwait: fatal: timed out
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Errors I noticed…
Plex Media Server.log:Oct 04, 2020 14:17:42.474 [0x151c06dd6700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:17:52.474 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:17:52.474 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:17:52.474 [0x151c04bc5700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:17:52.564 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:17:52.564 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:17:52.564 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:02.474 [0x151c047c3700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:02.474 [0x151c047c3700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:02.474 [0x151c047c3700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:12.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:12.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:12.474 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:12.568 [0x151c077db700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:12.568 [0x151c077db700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:12.568 [0x151c077db700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:22.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:22.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:22.474 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:32.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:32.474 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:32.474 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:32.580 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:32.580 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:32.580 [0x151c06dd6700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:42.475 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:42.475 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:42.475 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:52.476 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:52.476 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:52.476 [0x151c06dd6700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:18:52.593 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:18:52.593 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:18:52.593 [0x151c04bc5700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:02.476 [0x151c077db700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:02.476 [0x151c077db700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:02.476 [0x151c077db700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:12.476 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:12.476 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:12.476 [0x151c04bc5700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:12.596 [0x151c077db700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:12.596 [0x151c077db700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:12.596 [0x151c077db700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:22.476 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:22.476 [0x151c06dd6700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:22.476 [0x151c06dd6700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:32.476 [0x151c047c3700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:32.476 [0x151c047c3700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:32.476 [0x151c047c3700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:32.608 [0x151c077db700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:32.608 [0x151c077db700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:32.608 [0x151c077db700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:42.476 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:42.476 [0x151c07bdd700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:42.476 [0x151c07bdd700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:52.476 [0x151c077db700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:52.476 [0x151c077db700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:52.476 [0x151c077db700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14a8a700: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server.log:Oct 04, 2020 14:19:52.619 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, database corruption at line 65066 of [bf8c1b2b7a]
Plex Media Server.log:Oct 04, 2020 14:19:52.619 [0x151c04bc5700] ERROR - SQLITE3:(nil), 11, statement aborts at 13: [select statistics_bandwidth.id as 'statistics_bandwidth_id', statistics_bandwidth.account_id as 'statistics_bandwidth_account_id', statistics_bandwidth.device_id as 'statistics_bandwid
Plex Media Server.log:Oct 04, 2020 14:19:52.620 [0x151c04bc5700] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x151c14889700: sqlite3_statement_backend::loadOne: database disk image is malformed
