Plex stopped scanning library one week ago
Server Version#: 1.18.1.1973
Player Version#:[Plex Media Server Logs_2019-11-05_21-13-18.zip|attachment]( logs removed)(5.7 MB)
like the title says. for some reason plex stopped adding media about a week ago. if i do a manual scan it appears to complete instantly.
Do you mean auto detecting changes not working or even timed scans not working? your scanner logs say there is database corruption
Nov 05, 2019 20:43:49.463 [11040] ERROR - SQLITE3:0xa74e7553, 11, database corruption at line 85694 of [bf8c1b2b7a]
Nov 05, 2019 20:43:49.463 [11040] ERROR - SQLITE3:0xa74e7553, 11, statement aborts at 9: [select id from media_items where library_section_id=? and media_analysis_version<>?] database disk image is malformed
Nov 05, 2019 20:43:49.463 [11040] ERROR - Exception thrown while scanning: sqlite3_statement_backend::loadRS: database disk image is malformed
You if you have backups from more than a week ago or whenever it started you can try to restore one. ( you will need to scan things in again that were added after the back up was made)
or you can try to repair
@BigWheel
Thanks , i wasn’t really sure where to look in the logs. i’ve been having trouble with the OS drive. i suspect. I will try a restore. appreciate the help. thanks
