Shows not adding to plex
Server Version#: 4.116.1
i am using an unraid docker Plex-Media-Server
im having an issue and i dont know whats going on. currently when i have content added to my TV/Anime it doesnt scan/add to my libraries anymore. in fact TV is now missing from my Home Dashboard now. i can still play the content thats in my library just havent been able to get anything new. i have also tried renaming shows to the most basic forms of S01E01
Did you rename the media after it had been scanned incorrectly
-or-
did you “Plex Dance” the media and rename it while it was moved away?
yes after failed scan i didnt see anything get added.
show me the naming please, exactly as you have it?
i have plenty of examples but heres one “Helck - S01E13 - With Younger Brother in Tow HDTV-1080p” i believe the issue lies within the library/ it not adding to the home dashboard
Please do the following
  1. Verify server debug logging is enabled (settings - server - general - show advanced)
  2. Scan files
  3. Let it finish
  4. Download the server logs
  5. Attach the ZIP file here
please see attached
Plex Media Server Logs_2023-10-03_20-11-40.zip (4.8 MB)
You’ve database corruption.
Oct 03, 2023 20:08:58.382 [23157080795960] ERROR - SQLITE3:0x80000001, 11, database corruption at line 84326 of [a29f994989]
Oct 03, 2023 20:08:58.382 [23157080795960] ERROR - SQLITE3:0x80000001, 11, statement aborts at 14: [SELECT level, idx, end_block FROM 'main'.'fts4_metadata_titles_icu_segdir' WHERE level BETWEEN ? AND ? ORDER BY level DESC, idx ASC] database disk image is malformed
Oct 03, 2023 20:08:58.382 [23157080795960] ERROR - SQLITE3:0x80000001, 11, statement aborts at 178: [update metadata_items set updated_at=null,guid=?,hash=? where id=?] database disk image is malformed
Oct 03, 2023 20:08:58.383 [23157080795960] ERROR - Exception inside transaction (inside=1) (/data/jenkins/server/3534754019/Library/MetadataItem.cpp:3946): sqlite3_statement_backend::loadOne: database disk image is malformed
Oct 03, 2023 20:08:58.383 [23157080795960] ERROR - Exception assimilating media item in American Dad/Season 15: sqlite3_statement_backend::loadOne: database disk image is malformed
Download and run Chuck’s DBRepair Utility: GitHub - ChuckPa/PlexDBRepair: Database repair utility for Plex Media Server databases
The Readme has an example for running it in a Docker container.
Thanks @FordGuy61
You saw it just as I did :slight_smile:
its working again. Thanks for the help with this.
