Plex suddenly stopped working
Apple TV 3 and 6.2
192.168.1.136
192.168.1.136
Windows 7 desktop pc and 0.9.9.10
0.9.9.10
192.168.1.136
Downloaded the latest version today
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
Plex connect all of sudden stopped working so installed the new version from the github website and then when I installed the new version it couldn't connect to the plex server.
If i missed anything out let me know
Thanks in advance
Hm.
According to the log, PlexGDM definitely found your server.
Do you have playlist on that server?
As it looks to me, for whatever reason, you are kicked into the "Playlist" section, instead of the Library tab. This might be a bug in one of the templates (at least, I don't understand, why it is coded that way... :-).
Please just try again, but navigate to the Library tab. You should see your library sections there...
I *think*, this is how it should look like. Could you replace the attached file in /assets/templates and double-check?
Right that worked now thanks.
Just a tiny niggle is the fact that the metadata seems to take longer than before to load. Is that something to do with the update?
