Plex super slow upload speed
Server Version#: 1.16.1.1291
I’m getting super slow upload from my server regardless of the devices I’m using (remote).
Speedtest tells me I should have ~200-300 upload.
Anyone know what may be slowing down? I’ve tried watching the original quality with no luck…
CPU is not being utilized, so I can’t think it’s the transcode… I’m lost as to what is causing it…
dashboard
Need more info, what client are you having issue with? Working on any other clients, try Plex Media Player? In network or out of network when have the issue,etc?
Thanks for your reply, I tried both web client as well as the plex windows client. Having issues outside of the network when I’m having issues. My server local has 500 up (real up of 200-300), and my remote has 300 down. Port is forwarded, and setting says it’s working fine…
Not sure what else I can provide, but pls let me know.
  1. Provide screenshots of your router and server settings
  2. Try testing your port configuration via link https://canyouseeme.org/
  3. Have you viewed the dashboard when streaming from Plex to see what it shows
