Hello there, I’m currently backing up some anime, and the source includes 2 separate files for both sub and dub. I can merge these into one MKV (2 audio streams, 2 video streams, and 2 subtitles) but I cant view both the Sub and the Dub on the server, I was wondering if there was a way to make it so that I have the choice of either sub or dub without creating a separate entry for them all as they are still the same films and TV Shows after all
Server Version#:1.19.4.2902
Player Version#:1.12.0.1232-aacabe78
If Video has 608s or other embedded subs, not marking, or mismarking the Video with a language will display those subs as Unknown, or just wrong.
If Video has subs - whatever language they’re in - is the language you apply.
Otherwise - it doesn’t matter.
In this case each video is slightly different due to the different speed of the languages, if i try to use one video source but a different audio source, they will run out of sync of each other
