Does LG OLED65CX3LA 4K UHD support Plex?
Thanks.,
You shouldn’t really hijack a thread with an unrelated question.
I did not see the answer in theat thread
We don’t have info on every single model out there. You need to find out which Operating system your TV has. If it is a new TV with WebOS 4.0 and 4K as mentioned in the link for example then it should.
if you are considering buying a tv just because of Plex support. I think you should consider getting a streaming device like a Roku instead which you can use with any modern TV
Yes it does. There is even a beta you can join from inside the Plex app that will update automatically.
Its document says: “WebOs Smart”. No number
if you mean on LG’s website then I dunno why they don’t list it. did a google search
Great! Thanks!
I believe that TV is WebOS 4.5, CX meaning the 2019-2020 model
Yes, 2020 model.
