Plex server is unavailable on LG TV for several days. Everything works fine on the rest of the devices in the network. The TV has been reset to factory settings and installed PLEX again. It did nothing. Other applications like Youtube, Player are working properly.
Found this announcement in the forums. Would be good to confirm our model of TV is affected but again it would be too coincidental not to be the cause.
On September 30, 2020 we will be ending support for the Plex app on some older smart TVs. These devices are unable to use modern, secure connections when communicating with our services. TVs that are potentially affected by this include:
LG models running “Netcast” (the pre-webOS system)
Vizio models running “Presto” (models using a Mediatek chipset)
If a device is affected, the Plex app will no longer be able to function correctly on the device, unfortunately. We apologize for any inconvenience this may cause, and we encourage you to upgrade your Plex experience with one of several updated and affordable devices such as Google Chromecast, Roku Express, or Amazon Fire TV Stick.
Just to confirm my TV is currently running WebOS 4.1.4-5920 (goldilocks-glacier) and I am getting the error, however it’s not UHD which the release notes seem to indicate is required?!
You cheapest option is to buy a box like a Roku, Apple TV or prepare for further updates and buy a NVIDIA Shield. I know it not what you want to here, I was in the same situation 2 years ago. New TV or a Box, I bought a shinny new LG OLED. Great TV and so happy.
I have a similar problem here, out of nowhere my TVs no longer connect to the plex servers, I can’t log in anymore, 49LJ5500 webOS 3.8 and 32LM625 webOS 4.7.
It has something to do with the LG App. When I add my network as “List of IP addresses and networks that are allowed without auth” I can regain connectivity directly with the local Plex server application. When I remove those, the LG App cannot authenticate with Plex.TV which makes the application believe it has no connectivity. Plex needs to address the application failure on WebOS preferably 1.4 and forward
Same issue
LG 32LM630BPLA “[LG] webOs TV”
Web is ver 4.7.2-50911
Plex for LG 3.13.28
When hit “log in” from the error screen it either does nothing or it flicks my selection to retry
Tried these with no joy
log on web app and remove affected device, try to re register tv/app.
factory reset TV / redownload
enter server IP/Port manually
delete app and wait for a good while, power off for 30 seconds / back on / download … can’t say I understand it properly but a post somewhere mentioned the idea being to let it clear from cache
another post mentioned Plex support updating the version displayed in “about” from
3.13.28
To
3.13.29
And a few people said it fixed it / just re-download it - but realised that’s for netcast not WebOs… and besides I have the latest version I can from LG and that’s the former version (3.13.28)
a mi me pasa lo mismo pero tengo version de webOS 3.3.0 tendria q funcionarme, he desistalado y vuelve a instalar la version 3.15.28, en otra tv tb tengo webOS y me ha instalado la version 5.2.1, alguien sabe como se puede forzar para poner una version superor a la 3.15.28, si tengo la misma version de webOS 3.3.0 tendria q dejar instalar la misma app no??
Same here on an LG 42LB730 with WebOS 1.4.0 and Plex latest app from store (v2.2 by store but 3.13…28 by app settings about).
But I think it did not start at Sept 30th rather sometime last week.
Is this forum monitored by anyone from Plex support?
