Plex sync on a playlist
I posted in the Web client forum with no success so I am going to ask here.
I have all the sudden lost the option in plex Web to sync a playlist. Verified it’s there for my brother on his plex server but for me it just does not present the option at all. I can sync the same list from the android app.
Pretty sure this happened a few updates ago but can’t confirm 100% when.
Please any help would be appreciated
I just Updated to PMS v **1.8.3.4235 **with plex web v3.20.4 and i’m having the SAME Exact issue now!!! there is no Sync Option on PLEX WEB playlists anymore. please any help would be much appreciated!!!
The only way I have found - is to use the playlist Sync in the mobile app.
that is incorrect. prior to this newest PMS/Web release, if you were to go into your Playlist section and click the 3-Dot icon on the thumbnail of the playlist (as pictured above), there was a SYNC option in that menu which has now disappeared, and has not been replaced with any other icon/option to sync from the web client. I pretty much used this exclusively as it works so well.
Plex Devs, any help would be appreciated.
Just ran latest Update to plex web 3.20.5 and this did Not correct the missing Sync option either. please assist
I cant believe we are the only ones noticing this or have this issue. Anyone else?
