“PLEX” Tidal playlist don’t match content with Tidal so if an item isn’t currently available on Tidal, but is the Plex Tidal playlist it causes “NOT FOUND” errors and stops playback. The PLEX copy of the Tidal Playlist should always match the current Tidal copy. I’ve attached screen shots which show the error.
The Track: “Money In The Bank” shows on PLEX and tries to play, but if you look at the Tidal playlist you’ll see the track doesn’t exist. So when PLEX tries to play, the “NOT FOUND” error appears and the whole playlist grinds to a halt until manually restarted.
