Server Version#:3.108.2
Player Version#:6.3.14.5837 and 3.13.13
I use Plex with a Synology NAS and use 2 TV’s to watch content. One is a Samsung pre smart led TV and it shows the correct time including for daylight saving. The other is a Hisense Smart TV and does not pick up the daylight saving so is one hour behind. I have looked at everything and cannot fix it? any ideas. When the smart TV is in TV mode it shows the correct time.
Can you set the tv time manually an hour ahead or behind?
Thanks. I can manually change the time to be one hour out which may fix it but then the TV will be out. Most of my recording is done via Foxtel so it is not a huge problem just a bit annoying seeing the wrong time displayed. I may just disable the time from displaying if a fix is not found. It is only while Plex is up that the clock is wrong. Most illogical.
