Plex token
hello I continue to get an error with my plex token can you please assist I followed the change password from the article but still receive an error
Please provide lots more info about your problem, like:
  • What error?
  • What Client?
  • What server?
Im trying to connect plex meta manager and I continue to get a error when I use the token that is provided
Okay, made this into a public thread instead of a private message, since forums is all about sharing
Could you please upload a Screen Capture showing your error?
And if you also could answer the questions I asked before, it would also help
getting Plex Error: Plex token is invalid Ive followed the article to reset password to get plex token in which Ive copied and paste into plex meta manage
So:
  • Server: Synology
  • Error: Invalid token
Where do you see above error message?
I dont believe that it is safe to share a screenshot of my plex token along with my server details is it a support team for plex pass members
huh…
There’s something you are not telling us here!
plex.py belongs to a python api for 3rd. Party
Ref: plex.py · PyPI
So as already asked, and now again…
Where do you see that error?
no its nothing that Im not tell you Im getting this error after I try to connect plex meta manager which request for plex token I visit plex website and hit f12 to find the plex token
The Plex Meta Manager instructions refer to this Plex support document for obtaining a Plex token.
Finding an authentication token / X-Plex-Token | Plex Support
Have you done so, or are you following some other process?
F12 should not be necessary. Are you following other instructions that recommend using F12 (I assume to open browser developer/debugging tools?)
Have you confirmed that the token was copied correctly?
And there was :wink:
So you are indeed using a 3rd. Party tool, and is seen the error in that :wink:
@Volts pointed you towards a support article, that you can use to get your token
Im using plex to get my token which does not appear in URL Ive followed the article provide and still unable to get the correct plex token so that I can use with the 3rd party tool which will be plex meta manager
Does the Plex token works, if you go here:
https://plex.tv/api/servers/?X-Plex-Token=<PUT_TOKEN_HERE___AND REMOVE <> >
Im log into my account and the link does not work
Hold on - you can’t find a token, or you’ve found one, but it isn’t working?
If you can’t find a token, please share the exact steps you’ve taken - each exact thing you’ve clicked on, and details of what you see.
cant find plex token Ive used the support article step by step
  1. Sign in to your Plex account in Plex Web App
  2. Browse to a library item and view the XML for it
