Plex transcoder crash Unrecognized option segment_copyts
Server Version#: 1.43.0.10162
Player Version#: plex 8.6 build 9 on roku devices (hisense tv, roku ultra, etc)
For the last month or so, I have been getting transcoder crashes on Plex, it almost never happened before. It happens on dozens of shows. The episodes won’t even start, it crashes right away.
The only “workaround” I have found is to force burn in subtitles. The error logs shows “Unrecognized option ‘segment_copyts’.” “Error splitting the argument list: Option not found”
My next troubleshooting step would be to downgrade Plex server, which I don’t really want to do and I figured I would seek assistance here first!
Any idea what could cause this ?
Error log
Oct 17, 2025 00:51:51.478 [127759871761208] DEBUG - [Req#403657/Transcode/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS=‘/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/cf7e611-580b18dbc1ce38ef1c15aaf8-linux-x86_64/’ LIBVA_DRIVERS_PATH=“/config/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64” X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx “/usr/lib/plexmediaserver/Plex Transcoder” -codec:0 h264 -hwaccel:0 vaapi -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -analyzeduration 20000000 -probesize 20000000 -i /media/nvme-temp/chinese-series/Legend.of.the.Undercover.Chef.S01.1080p.WEB-DL.AAC2.0.H.264-MrHulk/Legend.of.the.Undercover.Chef.S01E02.1080p.WEB-DL.AAC2.0.H.264-MrHulk.mkv -start_at_zero -copyts -fps_mode cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD128,driver=iHD -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/71692bc0-47bc-47af-a251-4b681bf7c0a1/progress -filter_complex “[0:0]hwupload[0];[0]scale_vaapi=w=1920:h=1080:format=nv12[1];[1]hwupload[2]” -map “[2]” -codec:0 h264_vaapi -b:0 20121k -maxrate:0 20121k -bufsize:0 40242k -r:0 25 -sei:0 -a53_cc -force_key_frames:0 “expr:gte(t,n_forced*1)” -map 0:1 -codec:1 copy -copypriorss:1 0 -segment_format mpegts -f ssegment -individual_header_trailer 0 -segment_time 1 -segment_start_number 0 -segment_time_delta 0.0625 -segment_list “http://127.0.0.1:32400/video/:/transcode/session/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/71692bc0-47bc-47af-a251-4b681bf7c0a1/manifest?X-Plex-Http-Pipeline=infinite” -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 “media-%05d.ts” -map 0:2 -metadata:s:0 language=eng -codec:0 webvtt -strict_ts:0 0 -f segment -segment_format webvtt -segment_time 1 -avoid_negative_ts disabled -write_empty_segments 1 -segment_format_options flush_packets=1 -segment_copyts 1 -segment_start_number 0 -segment_list “http://127.0.0.1:32400/video/:/transcode/session/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/71692bc0-47bc-47af-a251-4b681bf7c0a1/manifest?stream=subtitles&X-Plex-Http-Pipeline=infinite” -segment_list_type csv -segment_list_size 5 -segment_list_unfinished 1 -fflags +flush_packets “media-%05d.vtt”
Oct 17, 2025 00:51:51.478 [127759871761208] DEBUG - [Req#403657/Transcode/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/JobRunner] In directory: “/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129-71692bc0-47bc-47af-a251-4b681bf7c0a1”
Oct 17, 2025 00:51:51.478 [127759871761208] DEBUG - [Req#403657/Transcode/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/JobRunner] Jobs: Starting child process with pid 107721
Oct 17, 2025 00:51:51.488 [127759852497720] ERROR - [Req#40366c/Transcode/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/71692bc0-47bc-47af-a251-4b681bf7c0a1] Unrecognized option ‘segment_copyts’.
Oct 17, 2025 00:51:51.489 [127759880563512] ERROR - [Req#4036ca/Transcode/f2ef7cfb-fcae-4c6d-9826-6ab0b7095bb6-2129/71692bc0-47bc-47af-a251-4b681bf7c0a1] Error splitting the argument list: Option not found
Oct 17, 2025 00:51:51.491 [127760254106424] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex Transcoder’ exit code for process 107721 is 8 (failure)
PMS-1.43.0 is beta and has known transcoder bugs.
Roll back to stable.
weirdly enough, I didn’t know I was on beta. I was using plex-latest (with plex-pass) but I didn’t associate that with beta.
I switched to public and it looks good so far.
