Plex Transcoder fails hardware encoding
Server Version#: 1.43.0.10389
Player Version#: Plex for Windows 1.112.0.359-0d79a49f Plex Web - General 4.156.0
I am running the plexinc/pms-docker:plexpass image with a Quadro P400. Hardware transcoding is failing in the Plex application (falling back to software).
I have performed isolated tests inside the container. Generic FFmpeg (installed via apt) can successfully encode using the GPU. However, the bundled Plex Transcoder binary fails to initialize the hardware decoder/encoder chain in the exact same session.
Environment:
  • GPU: Quadro P400 (Pascal)
  • Driver: 550.163.01
  • Image: plexinc/pms-docker:plexpass
  • Runtime: nvidia container runtime
Docker Compose:
plex:
  image: plexinc/pms-docker:plexpass
  runtime: nvidia
  deploy:
    resources:
      reservations:
        devices:
          - driver: nvidia
            count: all
            capabilities: [gpu]
  environment:
    - NVIDIA_DRIVER_CAPABILITIES=compute,video,utility
    - NVIDIA_VISIBLE_DEVICES=all
Preferences.xml confirms hardware acceleration is enabled:
[goose@Vergil: ...Application Support/Plex Media Server ] $ sudo cat Preferences.xml| yq -p xml | grep "Hardware"
  +@HardwareDevicePath: ""
  +@HardwareAcceleratedCodecs: "1"
  +@HardwareAcceleratedEncoders: "1"
The Environment is valid, nvidia-smi sees the card, and ldconfig sees the libraries mounted by the runtime.
root@plex:~# nvidia-smi -L
GPU 0: Quadro P400 (UUID: GPU-ddd2acf6-9620-6113-7328-bcfeb1e16728)
root@plex:~# ldconfig -p | grep -E 'libnvcuvid|libnvidia-encode'
libnvidia-encode.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/nvidia/current/libnvidia-encode.so.1
libnvcuvid.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/nvidia/current/libnvcuvid.so.1
I installed a vanilla ffmpeg (apt install ffmpeg) inside the container to verify the driver mapping. It works perfectly:
root@plex:~# ffmpeg -y -hide_banner -hwaccel cuda -f lavfi -i testsrc=size=1920x1080:rate=30 -c:v h264_nvenc -t 5 -f null -
Input #0, lavfi, from 'testsrc=size=1920x1080:rate=30':
  Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: rawvideo (RGB[24] / 0x18424752), rgb24, 1920x1080 [SAR 1:1 DAR 16:9], 30 tbr, 30 tbn, 30 tbc
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc))
Press [q] to stop, [?] for help
Output #0, null, to 'pipe:':
  Metadata:
    encoder         : Lavf58.29.100
    Stream #0:0: Video: h264 (h264_nvenc) (Main), rgb0, 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, 2000 kb/s, 30 fps, 30 tbn, 30 tbc
    Metadata:
      encoder         : Lavc58.54.100 h264_nvenc
    Side data:
      cpb: bitrate max/min/avg: 0/0/2000000 buffer size: 4000000 vbv_delay: -1
frame=  150 fps= 73 q=9.0 Lsize=N/A time=00:00:05.00 bitrate=N/A speed=2.45x
video:334kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
root@plex:~#
When running the exact same logic using the bundled Plex Transcoder binary, it fails to find the decoder libraries, despite listing h264_nvenc as an available encoder via -encoders:
root@plex:~# /usr/lib/plexmediaserver/Plex\ Transcoder
  -hwaccel nvdec \
  -i "/media/path/to/hevc_file.mkv" \
  -c:v h264_nvenc \
  -t 5 \
  -f null -
ffmpeg version ca90ef9-9a65c18385d96de09023e106 Copyright (c) 2000-2025 the FFmpeg developers
  built with Plex clang version 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
  configuration: --disable-static --enable-shared --disable-libx264 --disable-hwaccels --disable-protocol=concat --external-decoder=h264 --enable-debug --enable-muxers --enable-libxml2 --fatal-warnings --disable-gmp --disable-avdevice --disable-bzlib --disable-sdl2 --disable-decoders --disable-devices --disable-encoders --disable-ffprobe --disable-ffplay --disable-doc --disable-iconv --disable-lzma --disable-schannel --disable-linux-perf --disable-mediacodec --enable-eae --disable-protocol='udp,udplite' --arch=x86_64 --target-os=linux --strip=true --cc=x86_64-linux-musl-clang --pkg-config=/home/runner/_work/plex-conan/plex-conan/plexconantool/plex-pkg-config --pkg-config-flags=--static --windres=llvm-windres --enable-cuda-llvm --enable-libdrm --disable-beignet --enable-opencl --enable-cross-compile --ar=llvm-ar --nm=llvm-nm --ranlib=llvm-ranlib --extra-ldflags='-Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.3.19-1/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.21.0-9/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.3.19-1/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.21.0-9/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -m64 -L/home/runner/_work/plex-conan/plex-conan/.conan/data/opus/1.2.1-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libvorbis/1.3.5-44/plex/main/package/76eba14299c6c14bf4759b1da21aec07c9ca1a2f/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/dav1d/1.0.0-20/plex/main/package/4d954bcc6be6a68b775ef1b1bae9dd65e4e237ff/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/ffnvcodec/11.1.5.3-43d9170-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/x264/161-1086f45-34/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/zvbi/0.2.35-66/plex/main/package/7366a567f554439fb9e7a3415c9d1c2ea2b75360/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libass/0.17.3-6/plex/main/package/d81dbed7e8ad560c9ec55240308ceb55b203927d/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/mp3lame/3.98.4-38/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-media-driver/24.1.5-10/plex/main/package/bb11b771bdd2e73dbca3ba3fa4e91df6e323972a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-vaapi-driver/2.4.1-47/plex/main/package/54d41cda82931ea2b2be37156bad83b30007f4c5/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/opencl-icd-loader/v2024.05.08-861b68b-2/plex/main/package/421f4632684b64b7f88e2f734a2cb50980dd916d/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libogg/1.3.2-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/fribidi/1.0.12-7/plex/main/package/464531ac2a3f2ab2167bd10d1214603bc8116983/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/harfbuzz/4.2.1-11/plex/main/package/53415d552ac96104f622ffa8d8530937a40b4271/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.21.0-9/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.3.19-1/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/fontconfig/2.14.0-11/plex/main/package/aacc2a7710dfa87ed80d4eea45b80c93243fe456/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/freetype2/2.12.1-32/plex/main/package/82a00e1e4cc2e8878bb79ae9b5e2235fd8280e6a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/expat/2.6.4-1/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libuuid/1.0.3-33/plex/main/package/841d526523d3550ac4d52807df94cbbedce37e2c/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpthread-stubs/0.4-40/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/bzip2/1.0.6-43/plex/main/package/618bb3c469051b52e1349cf1a297263df374d15a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpng/1.6.37-47/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/zlib/1.2.11-37/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -Wl,--gc-sections -Wl,-z,noexecstack -Wl,-z,relro -g2 -gdwarf-4 -Wl,--build-id=sha1 -flto=thin -fwhole-program-vtables -Wl,--icf=all -Wl,--threads=6 -Wl,-O2 -l:libgcompat.so.0 -Wl,-rpath,'\''XORIGIN/../lib'\'' -Wl,-rpath,'\''XORIGIN/lib'\'' -Wl,--thinlto-cache-dir=/home/runner/_work/plex-conan/plex-conan/.conan/data/ffmpeg/6.1-ca90ef9a38-0/plex/main/build/ca208ecac61a85047320f1e22fc90f2cda48fc04/lto_cache/' --extra-libs= --enable-decoder=png --enable-decoder=apng --enable-decoder=bmp --enable-decoder=mjpeg --enable-decoder=thp --enable-decoder=gif --enable-decoder=dirac --enable-decoder=ffv1 --enable-decoder=ffvhuff --enable-decoder=huffyuv --enable-decoder=libdav1d --enable-decoder=av1 --enable-decoder=rawvideo --enable-decoder=zero12v --enable-decoder=ayuv --enable-decoder=r210 --enable-decoder=v210 --enable-decoder=v210x --enable-decoder=v308 --enable-decoder=v408 --enable-decoder=v410 --enable-decoder=y41p --enable-decoder=yuv4 --enable-decoder=ansi --enable-decoder=alac --enable-decoder=flac --enable-decoder=vorbis --enable-decoder=opus --enable-decoder=pcm_f32be --enable-decoder=pcm_f32le --enable-decoder=pcm_f64be --enable-decoder=pcm_f64le --enable-decoder=pcm_lxf --enable-decoder=pcm_s16be --enable-decoder=pcm_s16be_planar --enable-decoder=pcm_s16le --enable-decoder=pcm_s16le_planar --enable-decoder=pcm_s24be --enable-decoder=pcm_s24le --enable-decoder=pcm_s24le_planar --enable-decoder=pcm_s32be --enable-decoder=pcm_s32le --enable-decoder=pcm_s32le_planar --enable-decoder=pcm_s8 --enable-decoder=pcm_s8_planar --enable-decoder=pcm_u16be --enable-decoder=pcm_u16le --enable-decoder=pcm_u24be --enable-decoder=pcm_u24le --enable-decoder=pcm_u32be --enable-decoder=pcm_u32le --enable-decoder=pcm_u8 --enable-decoder=pcm_alaw --enable-decoder=pcm_mulaw --enable-decoder=ass --enable-decoder=dvbsub --enable-decoder=dvdsub --enable-decoder=ccaption --enable-decoder=pgssub --enable-decoder=jacosub --enable-decoder=microdvd --enable-decoder=movtext --enable-decoder=mpl2 --enable-decoder=pjs --enable-decoder=realtext --enable-decoder=sami --enable-decoder=ssa --enable-decoder=stl --enable-decoder=subrip --enable-decoder=subviewer --enable-decoder=text --enable-decoder=vplayer --enable-decoder=webvtt --enable-decoder=xsub --enable-decoder=eac3_eae --enable-decoder=truehd_eae --enable-decoder=mlp_eae --enable-encoder=flac --enable-encoder=alac --enable-encoder=libvorbis --enable-encoder=libopus --enable-encoder=mjpeg --enable-encoder=png --enable-encoder=rawvideo --enable-encoder=wrapped_avframe --enable-encoder=ass --enable-encoder=dvbsub --enable-encoder=dvdsub --enable-encoder=movtext --enable-encoder=ssa --enable-encoder=subrip --enable-encoder=text --enable-encoder=webvtt --enable-encoder=xsub --enable-encoder=pcm_f32be --enable-encoder=pcm_f32le --enable-encoder=pcm_f64be --enable-encoder=pcm_f64le --enable-encoder=pcm_s8 --enable-encoder=pcm_s8_planar --enable-encoder=pcm_s16be --enable-encoder=pcm_s16be_planar --enable-encoder=pcm_s16le --enable-encoder=pcm_s16le_planar --enable-encoder=pcm_s24be --enable-encoder=pcm_s24le --enable-encoder=pcm_s24le_planar --enable-encoder=pcm_s32be --enable-encoder=pcm_s32le --enable-encoder=pcm_s32le_planar --enable-encoder=pcm_u8 --enable-encoder=pcm_u16be --enable-encoder=pcm_u16le --enable-encoder=pcm_u24be --enable-encoder=pcm_u24le --enable-encoder=pcm_u32be --enable-encoder=pcm_u32le --enable-encoder=h264_vaapi --enable-encoder=hevc_vaapi --enable-encoder=h264_nvenc --enable-encoder=hevc_nvenc --enable-encoder=eac3_eae --enable-hwaccel=av1_vaapi --enable-hwaccel=av1_nvdec --prefix=/home/runner/_work/plex-conan/plex-conan/.conan/data/ffmpeg/6.1-ca90ef9a38-0/plex/main/build/ca208ecac61a85047320f1e22fc90f2cda48fc04/transcoder-install --enable-libzvbi --enable-openssl --enable-libass --enable-libopus --enable-libvorbis --enable-libdav1d --extra-cflags='-m64 -O3 -fdata-sections -ffunction-sections -fno-omit-frame-pointer -g2 -gdwarf-4 -fcommon -flto=thin -fwhole-program-vtables -I/home/runner/_work/plex-conan/plex-conan/.conan/data/opus/1.2.1-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libvorbis/1.3.5-44/plex/main/package/76eba14299c6c14bf4759b1da21aec07c9ca1a2f/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/dav1d/1.0.0-20/plex/main/package/4d954bcc6be6a68b775ef1b1bae9dd65e4e237ff/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/ffnvcodec/11.1.5.3-43d9170-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/x264/161-1086f45-34/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/zvbi/0.2.35-66/plex/main/package/7366a567f554439fb9e7a3415c9d1c2ea2b75360/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libass/0.17.3-6/plex/main/package/d81dbed7e8ad560c9ec55240308ceb55b203927d/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/mp3lame/3.98.4-38/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-media-driver/24.1.5-10/plex/main/package/bb11b771bdd2e73dbca3ba3fa4e91df6e323972a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libogg/1.3.2-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/fribidi/1.0.12-7/plex/main/package/464531ac2a3f2ab2167bd10d1214603bc8116983/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/harfbuzz/4.2.1-11/plex/main/package/53415d552ac96104f622ffa8d8530937a40b4271/include/harfbuzz -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.21.0-9/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.3.19-1/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/opencl-headers/v2024.05.08-8275634-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/fontconfig/2.14.0-11/plex/main/package/aacc2a7710dfa87ed80d4eea45b80c93243fe456/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/include/libdrm -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include/libxml2 -I/home/runner/_work/plex-conan/plex-conan/.conan/data/freetype2/2.12.1-32/plex/main/package/82a00e1e4cc2e8878bb79ae9b5e2235fd8280e6a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/expat/2.6.4-1/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libuuid/1.0.3-33/plex/main/package/841d526523d3550ac4d52807df94cbbedce37e2c/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/bzip2/1.0.6-43/plex/main/package/618bb3c469051b52e1349cf1a297263df374d15a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libpng/1.6.37-47/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/zlib/1.2.11-37/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -DLIBXML_STATIC -DFRIBIDI_LIB_STATIC -DNDEBUG'
  libavutil      58. 29.100 / 58. 29.100
  libavcodec     60. 31.102 / 60. 31.102
  libavformat    60. 16.100 / 60. 16.100
  libavfilter     9. 12.100 /  9. 12.100
  libswscale      7.  5.100 /  7.  5.100
  libswresample   4. 12.100 /  4. 12.100
[in#0 @ 0x7f76a40fcb40] Unknown input format: 'lavfi'
Error opening input file color=c=red:s=1920x1080:d=10.
Error opening input files: Invalid argument
root@plex:~#
The Docker/Nvidia Runtime is correctly mounting drivers to /usr/lib/x86_64-linux-gnu/nvidia/current/. Generic tools can find them. The Plex Transcoder binary appears to be ignoring these paths or failing to link against them at runtime?
Any suggestions on how to solve this, or acknowledge from the Plex team?
