I am running my Plex Server on a Raspberry Pi 4 and I have been trying to move my Application Support folder to another drive via various methods in order to stop space running out on my root directory from metadata buildup.
I first tried to change the location of the Application Support folder by writing a Plexmediaserver service override file and tell the server to place the Application Support folder on an external drive
And then I tried to mount an external drive directly to /var/lib/plexmediaserver/Library/
Both of these worked in getting the Application Support folder onto the external drive and the server runs and I can access it remotely and directly.
However, in both cases, the transcoder seems to stop working. I keep on getting “conversion failed. The transcoder exited due to an error” message, every time I try to play something.
I’ve attached logs of the issue here. If anyone can suggest a workaround, that would be great. I’ve run out of things I can think to try.
I tried deleting the codecs as well and letting the server download them fresh when trying to play the files again, but no luck either.
Cheers (2.4 MB)
Server Version#: 4.12.3
