Plex Trascoding
Server Version#: 1.24.1.4931
Does anyone have a idea why this is transcoding? i have a shield tv. other 4k works.
Unique ID : 219238456167221598073793619149113232095 (0xA4EFCA6FDC7E78308D7995F7681B8ADF)
Complete name : W:\Plex2-Movies\Movies-04-2160P-HDR\Stillwater (2021) (HDR) (2160P).mkv
Format : Matroska
Format version : Version 4
File size : 15.0 GiB
Duration : 2 h 19 min
Overall bit rate : 15.4 Mb/s
Movie name : Stillwater.2021.CMRG
Encoded date : UTC 2021-08-19 04:08:28
Writing application : mkvmerge v11.0.0 (‘Alive’) 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 14.8 Mb/s
Width : 3 840 pixels
Height : 2 080 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.077
Stream size : 14.4 GiB (96%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 987 cd/m2
Maximum Frame-Average Light Level : 137 cd/m2
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 638 MiB (4%)
Title : English
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 18 min
Bit rate : 49 b/s
Count of elements : 2089
Stream size : 49.8 KiB (0%)
Title : English [SDH]
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 2 h 11 min
Bit rate : 43 b/s
Count of elements : 1739
Stream size : 42.2 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
this one works fine
General
Unique ID : 12108534398818389333136117336453035851 (0x91C04D6820E00826C9E9CF1B742374B)
Complete name : W:\Plex2-Movies\Movies-04-2160P-HDR\Wonder Woman 1984 (2020) (HDR) (2160P).mkv
Format : Matroska
File size : 7.22 GiB
Duration : 2 h 31 min
Overall bit rate : 6 835 kb/s
Writing application : Lavf58.67.100
Writing library : Lavf58.67.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Height : 2 026 pixels
Display aspect ratio : 1.895
Color space : YUV
Bit depth : 10 bits
Writing library : x265 3.4+32-b24459657:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2026 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel layout : C L R Ls Rs LFE
Frame rate : 46.875 FPS (1024 SPF)
Writing library : Lavc58.122.100 libfdk_aac
Default : Yes
Forced : No
Text #1
Format : UTF-8
Duration : 2 h 27 min
Bit rate : 45 b/s
Count of elements : 1859
Stream size : 48.8 KiB (0%)
Title : English-SRT
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Default : No
Forced : No
Text #3
Format : PGS
Duration : 2 h 30 min
Default : No
Forced : No
Text #4
Format : PGS
Default : No
Forced : No
Text #5
Format : PGS
Default : No
Forced : No
Text #6
Format : PGS
Default : No
Forced : No
Text #7
Format : PGS
Default : No
Forced : No
Text #8
Format : PGS
Default : No
Forced : No
Text #9
Format : PGS
Default : No
Forced : No
Text #10
Format : PGS
Default : No
Forced : No
Text #11
Format : PGS
Default : No
Forced : No
Text #12
Format : PGS
Default : No
Forced : No
Text #13
Format : PGS
Default : No
Forced : No
Text #14
Format : PGS
Default : No
Forced : No
Text #15
Format : PGS
Default : No
Forced : No
Text #16
Format : PGS
Default : No
Forced : No
Text #17
Format : PGS
Default : No
Forced : No
Text #18
Format : PGS
Default : No
Forced : No
Text #19
Format : PGS
Default : No
Forced : No
thanks
