Plex Tuner Service aborting when stopping playback
Server Version#: 1.21.2.3943
Player Version#: via HTTP
Tuner Make/Model: TVButler 100C
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: IT doesn’t seem to matter
Feb 07, 2021 12:43:14.951 [0x7f812ee6b700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Feb 07, 2021 12:43:14.951 [0x7f812ee6b700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 62464:62464
Feb 07, 2021 12:43:14.989 [0x7f812d6fb700] DEBUG - [I] onetv_factory::GetTunerState. Signal stats: 1, 3100, -1
Feb 07, 2021 12:43:17.991 [0x7f812f159700] INFO - [I] web_service_t::process_device_status
Feb 07, 2021 12:43:17.992 [0x7f812f159700] INFO - [I] onetv_factory::DeviceGetListEx >>
Feb 07, 2021 12:43:17.993 [0x7f812f159700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
Feb 07, 2021 12:43:17.993 [0x7f812f159700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7449:256
Feb 07, 2021 12:43:17.993 [0x7f812f159700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Feb 07, 2021 12:43:17.993 [0x7f812f159700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 62464:62464
Feb 07, 2021 12:43:18.004 [0x7f812ee6b700] WARN - [E] http_streamer_t::handle_read: read_error: End of file (2)
Feb 07, 2021 12:43:18.004 [0x7f81343be700] WARN - [E] http_streamer_t: http write error
Feb 07, 2021 12:43:18.004 [0x7f812dcd7700] INFO - [I] http_streamer_t::send_thread_func: removing http client
Feb 07, 2021 12:43:18.005 [0x7f812dcd7700] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Feb 07, 2021 12:43:18.011 [0x7f812e5a1700] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer fd4fdaef-719a-4f07-b763-8ffe6886ed32
Feb 07, 2021 12:43:18.011 [0x7f812e5a1700] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Feb 07, 2021 12:43:18.011 [0x7f812e5a1700] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://9018:4168:4168
Feb 07, 2021 12:43:18.011 [0x7f812e5a1700] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://9018:4168:4168
Feb 07, 2021 12:43:18.017 [0x7f812d6fb700] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://9018:4168:4168
Feb 07, 2021 12:43:18.017 [0x7f812e5a1700] INFO - [I] transponder_streamer::start_idle_timer
Feb 07, 2021 12:43:18.017 [0x7f812f159700] ERROR - Error. Received SIGSEGV: Segmentation Violation.Plex Media Server Logs_2021-02-07_14-49-11.zip (6.1 MB)
After the service aborts it is respawned automatically but only a limited number of times (3) then it stays dead and I have to restart Plex manually.
If I could change the retry limit to infinity then at least I can live with it for now.
Does anyone know where this value lives? Thanks.
dmesg shows:
[306691.643054] Plex Tuner Serv[12569]: segfault at 0 ip 0000000000549121 sp 00007f2dc670f360 error 4 in Plex Tuner Service[400000+361000]
[306895.586792] Plex Tuner Serv[5821]: segfault at 0 ip 0000000000549121 sp 00007f887fffe360 error 4 in Plex Tuner Service[400000+361000]
[307115.797450] Plex Tuner Serv[7123]: segfault at 0 ip 0000000000549121 sp 00007ff445448360 error 4 in Plex Tuner Service[400000+361000]
I just updated to 1.21.3.4104 and it seems to have stopped aborting.
It fails to tune a LOT so I will continue testing.
