Server Version#: 4.47.3 or 1.21.1 (not sure what you need)
Player Version#: unknown
Tuner Make/Model: DVBLogic TVButler DVB-C/T/T2 (100tc)
Guide/Lineup name: Moving from BBC News HD to any other channel causes a segfault
Using XMLTV?: No
Channel number/Name: 107/ BBC News HD
Jan 09, 2021 17:14:34.807 [0x7fd504553700] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jan 09, 2021 17:14:34.816 [0x7fd4efd11700] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer c614b7c9-6f85-4602-9a88-a5001ead13dd
Jan 09, 2021 17:14:34.818 [0x7fd4efd11700] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Jan 09, 2021 17:14:34.818 [0x7fd4efd11700] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://9018:40960:40960
Jan 09, 2021 17:14:34.818 [0x7fd4efd11700] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://9018:40960:40960
Jan 09, 2021 17:14:34.823 [0x7fd4ef447700] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://9018:40960:40960
Jan 09, 2021 17:14:34.823 [0x7fd4efd11700] INFO - [I] transponder_streamer::start_idle_timer
Jan 09, 2021 17:14:34.824 [0x7fd504e1d700] WARN - [E] Error. Received SIGSEGV: Segmentation Violation.
Moving from 107 to another channel causes a segfault. Channel 108 is also HD but does not segfault.if you change channel. This is reproducable.
Same if you just close the player - it aborts. So it doesn’t look like a change channel issue, more of a closing a channel issue.
Update: Switching from other (non-hd) channels can also cause an abort (from 001 to 004). This is inconsistent though.
I have a core dump if anyone wants it.
