Server Version#: 1.22.1.4200
Player Version#: 4.53.0
Tuner Make/Model: Hauppauge winTV quadHD USB
Guide/Lineup name: Local Broadcast (Omaha, NE)
Using XMLTV?: no
The tuner service is failing with segfaults 2-3 times a day. I can’t see a pattern. It’s not only when there are multiple shows to record. It mostly happens after recordings are done, but it could be 1 recording or 4. I’ve seen it happen when there are no recordings. Most of the time the service restarts but I’ve still missed the recording.
Are these reports being automatically sent to Plex? Anyone looking at these? Any specific debugging?
Ubuntu 20.04 LTS, kernel 5.4.0 using the Hauppauge PPA.
If I enable partial show recording, will it pick it up without much loss, say 30 seconds? The service seems to restart immediately.
Forgot to include samples:
/var/log/syslog:Mar 23 11:00:03 gatekeeper kernel: [866366.327101] Plex Tuner Serv[243584]: segfault at 0 ip 0000000000549201 sp 00007f8de89b4340 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.1:Mar 22 11:24:31 gatekeeper kernel: [781435.232589] Plex Tuner Serv[2188081]: segfault at 0 ip 0000000000549201 sp 00007fb7cd914340 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.1:Mar 22 18:00:02 gatekeeper kernel: [805166.208250] Plex Tuner Serv[3646410]: segfault at 20 ip 00000000004772d6 sp 00007f7479ffaae0 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.2.gz:Mar 21 17:00:02 gatekeeper kernel: [715166.516065] Plex Tuner Serv[2289406]: segfault at 0 ip 0000000000549201 sp 00007fc355963340 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.2.gz:Mar 21 22:00:02 gatekeeper kernel: [733166.475656] Plex Tuner Serv[1741247]: segfault at 0 ip 0000000000549201 sp 00007f9cfb7fd340 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.3.gz:Mar 20 05:30:01 gatekeeper kernel: [587366.398677] Plex Tuner Serv[685905]: segfault at 20 ip 00000000004772d6 sp 00007f4c637fdae0 error 4 in Plex Tuner Service[400000+361000]
/var/log/syslog.4.gz:Mar 19 14:00:05 gatekeeper kernel: [531570.298169] Plex Tuner Serv[3921005]: segfault at 7fbf88000480 ip 00007fbf88000480 sp 00007fbf95ffaad8 error 15
/var/log/syslog.7.gz:Mar 16 05:30:01 gatekeeper kernel: [241767.879009] Plex Tuner Serv[2758911]: segfault at 20 ip 00000000004771f6 sp 00007f8adaffcae0 error 4 in Plex Tuner Service[400000+361000]
