Server Version#: 1.15.2.793 running on the latest OpenMediaVault 4
I’m not sure what logs I should post but can get any that are needed.
https://plex.tv/api/resources? shows my public IP as 172.98.67.93
The server is running in docker using host for the network configuration and I have tried restarting it, building from scratch, taking down the docker and bridge interface on the network and rebuilding from scratch, setting my preferred interface as ens18.
Here is the details section of the container:
"Id": "b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663",
"Created": "2019-03-25T01:03:35.25490015Z",
"Path": "/init",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 25742,
"ExitCode": 0,
"Error": "",
"StartedAt": "2019-03-25T01:03:35.507543853Z",
"FinishedAt": "0001-01-01T00:00:00Z"
"Image": "sha256:f7b7b3911fd489c970e7210be1eea29c3705c7ffb84b3ec3535f4998b6f44063",
"ResolvConfPath": "/var/lib/docker/containers/b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663/hostname",
"HostsPath": "/var/lib/docker/containers/b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663/hosts",
"LogPath": "/var/lib/docker/containers/b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663/b61a8b98b28e5285b4e78b6f5f6115dba4a40914becbcb3971f24b3df738e663-json.log",
"Name": "/Plex",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "docker-default",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/sharedfolders/AppData/Plex:/config:rw",
"/sharedfolders/AppData/Plex Transcode:/transcode:rw",
"/sharedfolders/media:/media:rw",
"/etc/localtime:/etc/localtime:ro"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "host",
"PortBindings": {},
"RestartPolicy": {
"Name": "always",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "shareable",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DiskQuota": 0,
"KernelMemory": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": 0,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/17cae4bf5efa7cd4c2d655f14d25b793041e41feccef51105bbc25827caf1e5c-init/diff:/var/lib/docker/overlay2/7a27b59d9d87b06e31ac93cf23d09362c2ee67937be6506ed9d922ecfeee944c/diff:/var/lib/docker/overlay2/150f0a6ef431fb1e555679c49687e9c60d5a7c304ec0cea19d6da6a121efb06c/diff:/var/lib/docker/overlay2/6aca29bba566b0d5fff6657ef56a69cc5b08d2002c25e2844b6f7c8c0ccfbe4a/diff:/var/lib/docker/overlay2/d0d204e8ded6a6891fbaa24f74de77585f5a11cfdcd3c21c4d5369db111c30f8/diff:/var/lib/docker/overlay2/e57fdd6df68db62615bac0e4c60df608aebd8f964eae5fe0ef1a293841ac02de/diff:/var/lib/docker/overlay2/012f44dc8ac705a11b43a7130752852cdfba19c8a3bf7e21d58a1557b2cb04c3/diff",
"MergedDir": "/var/lib/docker/overlay2/17cae4bf5efa7cd4c2d655f14d25b793041e41feccef51105bbc25827caf1e5c/merged",
"UpperDir": "/var/lib/docker/overlay2/17cae4bf5efa7cd4c2d655f14d25b793041e41feccef51105bbc25827caf1e5c/diff",
"WorkDir": "/var/lib/docker/overlay2/17cae4bf5efa7cd4c2d655f14d25b793041e41feccef51105bbc25827caf1e5c/work"
"Name": "overlay2"
"Mounts": [
"Type": "bind",
"Source": "/etc/localtime",
"Destination": "/etc/localtime",
"Mode": "ro",
"RW": false,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/sharedfolders/AppData/Plex",
"Destination": "/config",
"Mode": "rw",
"RW": true,
"Type": "bind",
"Source": "/sharedfolders/AppData/Plex Transcode",
"Destination": "/transcode",
"Mode": "rw",
"RW": true,
"Type": "bind",
"Source": "/sharedfolders/media",
"Destination": "/media",
"Mode": "rw",
"RW": true,
"Config": {
"Hostname": "OMV4",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"1900/udp": {},
"32400/tcp": {},
"32400/udp": {},
"32469/tcp": {},
"32469/udp": {},
"5353/udp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"LANGUAGE=en_US.UTF-8",
"DEBIAN_FRONTEND=noninteractive",
"PGID=100",
"PLEX_MEDIA_SERVER_INFO_DEVICE=Docker Container (LinuxServer.io)",
"LANG=en_US.UTF-8",
"HOME=/root",
"NVIDIA_DRIVER_CAPABILITIES=compute,video,utility",
"PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver",
"PLEX_DOWNLOAD=https://downloads.plex.tv/plex-media-server-new",
"TERM=xterm",
"PUID=1000",
"PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/config/Library/Application Support",
"PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6",
"ADVERTISE_IP=[CENSORED BUT CORRECT PUBLIC IP",
"PLEX_ARCH=amd64",
"PLEX_MEDIA_SERVER_USER=abc",
"PLEX_MEDIA_SERVER_INFO_VENDOR=Docker"
"Cmd": null,
"Image": "linuxserver/plex:latest",
"Volumes": {
"/config": {},
"/transcode": {}
"WorkingDir": "",
"Entrypoint": [
"/init"
"OnBuild": null,
"Labels": {
"MAINTAINER": "sparkyballs,TheLamer",
"build_version": "Linuxserver.io version:- 1.15.2.793-782228f99-ls12 Build-date:- 2019-03-21T13:02:30+00:00",
"maintainer": "sparklyballs, thelamer"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "b87feafdb40b1947e62380a68145956a46ac6add7127ccee00b6e5da9302380b",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/default",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"host": {
"IPAMConfig": null,
"Links": null,
"Aliases": null,
"NetworkID": "336db7655aa4d5f1ff2113aa3b64b6a31867f0ceb4e9e062662527b6bd41ea01",
"EndpointID": "5045e0c360d8a30314d3da327169c444cdad52288d794dbcc3b4b0871e5127f4",
"Gateway": "",
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"DriverOpts": null
