I have a Plex server (v1.8.0.4109) running on a QNAP NAS (TVS-671, if that changes anything). I’ve just purchased a HDHomeRun and have it connected to my network.
I’ve set the IP address for the HomeRun to a manual address so it doesn’t change. I am log into its web interface with both the IP address and via ‘http://my.hdhomerun.com’.
I’ve followed the instructions from the Plex website and gone to ‘Settings -> Server -> Live TV & DVR (Beta)’ and tried to setup the HomeRun however it keeps searching. I’ve tried adding the IP address manually however it fails and says it can not connect.
@rouq said:
Do you have a firewall running on your NAS? If so, disable it temporary to see if it is the culprit.
Not that causing it
@johnm_ColaSC said:
Also have seen other threads on the forum where the HDHR was in a different subnet than the PMS Server. HDHR needs to be on same subnet as the server.
On the same subnet 255.255.255.0.
Its something on the NAS / PMS on there as I’ve installed PMS on my MacBook and it connect without any issues.
