roehm
January 27, 2022, 11:47pm
1
Server Version#: 1.25.4.5468
I noticed after one of the beta server updates users on mobile networks were not able to access the server.
C:\Program Files (x86)\Plex\Plex Media Server
the plex relay exe was not working due to the following 2 dll’s were missing from the folder
cygwin1.dll
cyggcc_s-1.dll
So FYI if anyone is having this issue this is how to fix it
I would recommend disabling Replay
Settings \ Network (Show Advanced) \ (Uncheck) Enable Relay
Typically Relay is used when standard remote access is not working, you may need to check your remote access configuration.
roehm
January 31, 2022, 5:34pm
3
I just have no luck accessing plex using a cell network (Verizon) without it on. Both App and webpage will not connect.
tom80H
January 31, 2022, 5:38pm
4
Did you already have a look at the troubleshooting support article posted by nathanstorms?
There’s also a guide with some more details… if you want to dig into the remote access problems, you’ll need to dig a little deeper into your own setup:
When it comes to remote access, there’s a lot of different factors which can impact your setup. Some are under your own control, others not so much.
First off… there’s a dedicated support article on troubleshooting your remote access . I strongly recommend you have a look at that.
Find below some additional remarks on how to troubleshoot your remote access setup.
Review your internet access / remote access configuration
It’s good practice to review if Plex gets the correct public IP address…
Volts
February 1, 2022, 8:24am
5
It looks like the relay DLL issue was addressed in the latest update.
Plex Media Server - #484 by drzoidberg33
(Windows) The relay executable would not launch.
