The Basics of Remote Access Troubleshooting
When it comes to remote access, there’s a lot of different factors which can impact your setup. Some are under your own control, others not so much.
First off… there’s a dedicated support article on troubleshooting your remote access. I strongly recommend you have a look at that.
Find below some additional remarks on how to troubleshoot your remote access setup.
Review your internet access / remote access configuration
  • It’s good practice to review if Plex gets the correct public IP address of the main router in your home network.
  • Make sure your router is configured to assign the same static local IP address to your PMS (e.g. IP reservation)
  • Plex’ remote access depends on your home network to have a publicly routable IPv4 address. Common problems are environments where your ISP assigns only a private IPv4 address or no IPv4 address at all (some ISPs have started moving their network entirely to IPv6).
UPnP vs. manual port forwarding
Not all routers support manual port forwarding. Though based on experience in the forum, manual port forwarding seems to be more stable/reliable – there’s e.g. less remote access dropouts if the router shifts your UPnP connection to a different port.
Therefore, if possible, try to disable UPnP and establish a manual port forward to your router instead.
General configuration
Wording of those properties will vary depending on your router; some vendors e.g. use External/Internal instead of Public/Private.
Property Configuration
Protocol TCP
Public IP this will be the router’s public IP address (WAN IP); some routers expect it to be entered as a separate property anyway
Public Port you’re free to pick this value… preferably pick one in the range of 20000 to 50000 to avoid accidental collisions
Private IP <local IP of your PMS>
Private Port 32400
http://portforward.com/ has a wide range of manuals on how to configure a manual port forward for specific routers.
What’s wrong?
If Plex’ remote access still isn’t working after enabling your manual port forward, it’s time to dig deeper. Test if you can see the router’s public IP and the specified public TCP port. You can do this using a service like canyouseeme.org.
This is usually another opportunity to verify if the public IP they see is the same seen by Plex and your router itself.
  • If you can see your router, this implies the issue is inside your home network (between your router and the Plex Media Server, including both endpoints).
  • If you cannot see your router, this implies the issue is outside your home network (between “the internet” / your ISP and your router)
(1) Common issues
  • Plex remote access settings show that it’s working… then it’ll lose access after a few seconds/minutes
    Best way forward: Assume that your remote access setup isn’t working at all. Plex takes an „optimistic approach“ to displaying the remote access status — it’ll display that everything is working while still testing the status. This usually takes a few seconds… it’s not unheard of to take 20-30 seconds or in exceptions up to 1-2 minutes.
  • Despite all the effort… reality shows that errors happen all the time (stupid typos, mismatching configurations…)
    Best way forward: Double-check the manual port forward configuration of your router
  • Anything VPN
    Best way forward: The easiest way forward should be creating an exception for Plex to bypass the VPN. I take it that’s not a satisfying solution for some… which will leave you with lots of individual troubleshooting beyond this post/thread.
    There’s e.g. a number of known “VPN helper tools” which will write IP addresses to the server’s hosts file that can give Plex some hiccups.
(2) Common “inside your home network” issues
  • Hierarchical home network configuration and segmentation getting in the way; some active network components create their own subnet inside your home network.
    Best way forward:
    • Accidental segmentation: Review the configuration of your active network components (e.g. WLAN access points, other routers inside your home network). If possible, set them into “bridge mode” by disabling their built-in DHCP server. This way they should get their IP addresses from the main router and no longer form an obstacle for your remote access.
    • On purpose: If you segmented your home network on purpose, review those configurations and make sure to forward the communication through ALL of those network (from the main router down to the subnet hosting your PMS).
      This can also apply to containerized PMS setups which don’t use bridge network mode!
  • Security restrictions implied by firewalls or security tools
    Best way forward: Temporarily disable such components one-by-one to figure out which of them is impacting the Plex remote access communication. If needed, adjust their configuration to allow
  • Windows network profiles getting in the way → if you’re hosting your PMS on a Windows machine which has classified your network as public, this can block it from allowing outside access to the PMS
    Best way forward: Change the network classification to private.
    https://docs.microsoft.com/en-us/answers/questions/73866/how-to-change-network-settings-from-public-to-priv.html
  • Bad Plex remote access configuration
    Best way forward: Double-check your configuration matches that of the manual port forward; sometimes it can help to also look into the Plex network settings (e.g. some bad custom access URLs / certificates…).
(3) Common “outside your home network” issues
  • ISPs blocking certain ports…
    Best way forward: You can attempt changing the public TCP port of your port forward… until you find one that works. Sometimes it’s enough to use a port different from 32400, sometimes you have to go a long way.
  • ISPs blocking certain traffic (some more advanced filtering)
    Best way forward: Talk to your ISP
You don’t need a “static public IPv4” address for Plex remote access to work. That won’t stop many ISPs from offering such an option… usually for a steep price.
What else could be wrong?
After you’ve verified the above and your remote access issues persist, you might want to take a look at your server logs. Specifically search for…
  • Error messages and references of certificate issues (this is usually linked to error code 429). This usually indicates an issue of your server obtaining a new certificate. This usually implies some connectivity issue (e.g. your server failing to resolve the address providing the certificate) or might require a certificate reset by a Plex team member.
  • References to Rebind errors. Those can be fixed by allowing a rebind protection for plex.direct (see: “Why isn’t it working? (DNS rebinding)” in the support article on How to Use Secure Server Connections); sometimes, changing DNS could also resolve those (e.g. switching to Google DNS or Cloudflare public DNS).
What I am doing wrong? Remote Access works for a while then it goes into indarect
Plex shows server is available remotely, but it is not working
Trying to get remote access to work in Plex on my computer
Plex unreachable from mobile networks
Remote Access keeps disconnecting
Broblem mit dem Fernzugriff
Media-Server Remote Access - "Not available outside of your network"
Remote Access switches off
I need some help with Plex Setup
Remote Access Problems
Cannot access media outside Home network, even with Plex Pass
Remote Access stopped working unexpectedly
Kein Fernzugriff mehr möglich
Orbi/Plex Remote access not working - Relay only
About remote access
Local "remove access" shows connected, server unavailable externally
Remote Listening is VERY Unreliable
RE: Mobile not connecting
Live TV on the plex using hd Homerun
Error remote access
Another one... I know. I CANNOT Direct Play on ANY device when not on Home Wifi
Remote-Streaming mit max. 720p
Plexamp No Longer Sees My Music Library After Account Password Reset
NAS online but unable to connect to plex
Can I access my server remotely?
Not available outside your network
Upgraded router and can no longer access PLEX remotely
Having problems with remote playback even with my new FF Broadband?
Ich erhalte die Meldung das der Server zwar bei plex angemeldet ist aber keine sichere verbindung
Remote Access not working, despite port forwarding
Limited Quality Remote Playback on Roku — New Plex User, Need Advice
Quick connect synology
Remote Access Keeps disconnecting every 30 secs
Multiple issues with plex
Remote Access stopped working yesterday
Unable to connect to Plex server securely
Acces outside of my network config problems
Plex remote access issues - cannot connect securely
Remote access suddenly won't stay connected
Remote access briefly succeeds before failing
Remote access problem
Synology Plex server Unable to access using external network
Plex Web playback gives playback error s1001 (network) on all media
Cannot Remote Stream
Remote access disconnects after a few seconds
Plex remote access keeps disconnecting
Remote access headache
Remote access error and not enough power to convert video
Remote streaming not direct from server but always fallsback to 720P 2mbps through relay
Remote access not working. Indirect play. Users not being able to stream
Nicht außerhalb deines Netzwerks verfügbar
Cant get plex to work outside network full plex pass -outside network in green
How to force plex to Redo the uPnP rule
Can't get remote access to connect
New i5 NUC issues: remote access, limited connection, transcoding
Remote Access Super Unstable
Remote Access has stopped working
New Broadband Remote access no longer working (UK - Voneus)
Problema con attivazione porta pubblica
Remote access just stopped working
Given library access to brother with plex account but he can barely connect
Change my public IP as Remote Access fails
Remote access works for 5 seconds, then stops
Remote Access is not connecting issue
No remote access using Nord VPN meshnet
DSM 7.3.2 Update 3 broke Plex
Remote access drops
Can only get INDIRECT connection
Remote Access
Inconsistent Remote Access Experience
Remote Access Stopped and cant get it working!
Not available outside my network
Configuration
Remote access: I give up
Cannot get remote access enabled - have covered troubleshooting, reaching out for help
Cannot connect remotely from truenas
Plex not available outside your network
Buffering via static IP on CGNAT network, how to fix?
Poor streaming quality due to incorrect bandwidth estimation
Remote acces from Kubernetes and NGINX as a proxy
Loss of remote connection and restoration via the "retry button"
Remote Acess Just stopped working after years of no issues
Plex with not play across mobile data on my android phone
Fixing indirect connect
Remote Access via ZTE MC888 5G Modem
Remote access enabled, cannot access server over internet outside of LAN
I can't acces my Synology Plex Media Server remotely
No full quality out of home even with plex pass
Plex remote access working fine for years but now drops out after 10 seconds or so
Remote Access Issue
Remote access issues after update
Remote Access Not Working Anymore
Remote Access Lost After Upgrading FIOS Router
Lost remote access connecting after updating server
Plex Remote Quality Stuck At 720p 2Mbps
Unable to remote access server on one of two local servers
Trouble with remote access reseting
Acceso Remoto
Any Thoughts? Can No Longer Stream Any Video Media, Only Music
Plex server not available outside network since last update
Remote Access Stopped This Week
No libraries found away from home
Indirect Access when Remote Access is Successfully Enabled
Remote connection/access not possible,Port 32400 is enabled
Acceso remoto
Remote access quit working, unsure what to do
Remote access is patchy app to Home PC
Plex pass not worth it anymore
Can’t connect to remote access
Need help
My server will be fine for about 24hrs,and then seemingly go offline for no reason
Not authorized - You do not have access to this server
New Plex Server / Remote access
Plex Converts Video Quality Of 4K / HD Movies To 480P Also Unable To Enable Remote Access
Remote buffering only stored media
Remote Access & other Features : Please fix issues
Others with Remote Access rights experiencing very low Mbps download speeds
Remote connect has worked for months now it is not
Saying not available randomly but still seems to be
ASUSTOR remote access on/off
Home and away
Remote access worked automatically for years on my personal computer but suddenly no longer works
Plex remote "not avaible" and indirect connexion
Some Indirect Connections to PMS
Remote access - wavlink quantam d6
Remote streaming terrible quality
It is driving me crazy!
Poor quality while streaming
Remote Access - Disconnecting every 2 seconds
ACCESO REMOTO DESCONECTADO (No disponible fuera de tu red)
HELP! Lost Server and cant get it back
Simple advice on starting to use Plex remote access
Remote connections are indirect
Issue with Remote Access
Not available outside your network Your server is signed in to Plex, but is not reachable from outsi
Remote access not available outside my network
Remote access
Remote Access
Remote Access broken after update
Remote Shows Fully Accessible but isn't
Remote Access only 720p
Plex server shows "indirect connection"
Plex desktop app
Help with remote access PLEASE!
Remote Access will not stay connected
I'm giving up on this remote access feature completely
Remote keeps disconnecting
Remote Access Borked
Remote access drops out
Remote Access only Fully accessible for about 10 seconds
Unable to get Live TV & DVR on new laptop to work with TV tuner
Remote Access with multiple network devices? (extenders)
Conexion indirecta
Plex Pass purchased but NO download button shows anywhere
Plex Remote Access Intermittently Turning Off and On
Unable to upload from WD NAS Drive
Low quality on any device
No direct Stream on Nvidia Shield TV, No way to enter the server IP manually
How to make Remote Access work
Quality limitation on remote connection? 1Mbps
Direct play remotely, already seeing fully accesible message on dashboard
Remote Access new v. 1.27.1.5916 not working again
Remote connection will not connect or drops
Almost Got Remote Access Working
Aaaaarrrrgh! CANNOT keep remote access working!
NVIDIA Shield - remote access
"Fully accessible outside your network" but I can't access it through my phone's LTE
Troubleshooting Remote Access - TP link nano
Plex Remote Stream Quality stuck at 2 mbps
Off Network viewing
Bandwidth limit with Plex
Local & Remote Access -- It Was All Fine Until It Wasn't
Remote Access Enabled, but isn't
Indirect play fix
No Remote Access
Remote Access won't stay enabled
Acces from ouside instable
Cannot access my videos with Plex app on iPhone on cellular data
Problems with remote access outside with using synology ds218 and using my router tp-link ax5400 wifi 6
Remote Access unavailable Randomly "Not Available Outside Your Network"
Can't remote access to QNAP NAS using Port Forwarding
Remote access problems
Remote Access continually disconnects
PMS says "Fully accessible outside your network" but Android app shows Server Offline
Plex was working great until I reinstalled Windows 10 - now videos all look blurry
Remote access says not available but still is
Remote streaming without use of replay feature
Video Quality poor
Can’t connect to server outside local network even if remote access is set-up manually
Low resolution pixelated video playing despite "Original Quality" selected, on 4k / 1080p content
Poor picture quality when watching remotely using smart tv or ipad
PMS on Synology - New Home and New IP Range
Remote Access only over port 32400
Cannot access Plex outside home network
How to fix the Bug "Indirect Play"?!
Can't Download or Stream Content > 2000 bit
Remote access incredibly temperamental
Low quality on remote access
New ISP, New Router, Remote access is indirect connection...need help configuring
Can’t enable remote access
Remote Streaming buffering for past week
Updated router today, lost remote access, and all connects indirect now
External access (Port forwarding for Remote Access or just login to plex.tv ?)
Bandwith limit to 1000kbits Plex on Shield TV 2019
Mobile iPhone not connecting directly to server
Issue REmote access - Not available outside your network
Remote streaming issues
Unable to set up Plex on My Cloud
Remote Access is no longer working!
Plex Remote Access not working
Remote access disabled
Video en 320p
Remote Access doesn't work after last update
Remote Access Green and Red icon?
Transcodes are being limited to 2.0 Mbps/720p
Remote Access
Quality issues streaming remotely
Remote access disabling every few seconds
Remote access turns on and then off
How to completely start over with plex?
PLEX finds no content
Remote sever wont stay conneted
See content outside the home
Remote access
Plex library not "available" to shared accounts
WAN streaming issue (2Mbps max)
Quality of playback on remote access
Plex quality very low outside wifi
Remote access issues after port forward/turning off firewall.
Remote Access connects for a few seconds and then drops
Quality are converted, allthough settings are for direct stream
For the love of god!
Windows 10 Plex remote access
Plex media server remote access not working
How to address Indirect connections
Making plex listen to DDNS address
Using Plex Media Server across different PC accounts
I cannot achieve direct remote access on either of my Asustor servers
Why isn't it showing other quality options? Where's the 1080 and the other 720s?
Indirect access help
Issue with my server, remote access
Unmotiviertes Abschalten des Fernzugriffs
"Non disponible en dehors de votre réseau local"
Media not available after installing glasfiber
Port Forwarding not working after changing Broadband provider
Need Help! Cannot setup remote access, always gets disconnected
Fernzugriff
Remote Access shows green, no Firewalls, but isn't reachable
Remote Access not working/working really really inconsistently
Problem with video quality
Plex remote setup on pfsense with PIA vpn setup
Plex no remote access
Own IP behind Proxy, set Remote IP?
Remote Server Will Not Stay On!
Strange Remote Access Behaviour
Remote Access
Remote Access issues
Remote Access with DD-WRT on Netgear R9000 not working
Can't see PMS on Shield on Deco Mesh on BT Fibre Hub
Remote Access
Only 360p video playback when outside of network
Remote access disabled; unable to enable
Remote Access
Users Only Connect "Indirectly"
Remote streaming in SD
Setting up video streaming outside your home network
Unable to Port Forward
Remote Access keeps going red
Plex Media Server 1.41.7.9717 remote access no longer working
Remote Access Cuts in and Out - Windows 11 Server 1.41.2.9200
Remote Access DSM 7.7.2 PMS 1.41.0.8911
Remote access / quality issues
PMS remote access connects (actually has access remotely) for about 15 seconds then not available
Port 443
PlexMediaServer-1.41.2.9200-c6bbc1b53-universal BROKE LIBRARIES
Plex android player says my NAS is offline, but it's not, won't play on 5G, but will play on WiFi
Remote access no longer works
Need help with Remote access
Remote Access Setup
Remote Access Setup
From Bad to Worse. Now Remote Access Not Working
Remote Access has been broken by last few updates
TrueNAS Scale - Plex, how to start - Remote Access Problem
Error during setting up remote access. Mapped - Not Published (Not Reachable)
Enabling Remote Access
Public ip
BufferingI have about 200 movies saved in a different house on hard drive and I’m trying to access t
Remote access is enabled, but server cannot be accessed remotely
Plexamp remote sync
Remote not working on PLEX Synology
Plex Server not available off network
Can't access videos outside of network but can play music
Remote Access keeps coming "Off"
Relay Connection
Windows server and ORBI router remote access issues
Plex Remote access issues
Can't access server remotely
Remote Access Not Available outside your Network - Already Set up Port Forwarding, No Luck!
Remote Access Setup on a Win11 PMS
Remote Playback Not Working
Remote Access Troubleshooting Arris NVG589
HELP! Low quality while on remote connection
Port forwarding for Plex is not working
Poor video quality streaming to Apple TV
Plex control, playing, accounts
Outside local network fails
Issue With Plex Media Server Remote Access
Remote Access Not Available outside WiFi Network
Remote access works then stops
Plex only available via Plex Relay & Remote Access always changing from green to red after a few sec
Purchased Monthly Remote Watch Pass and still getting low quality movies
Remote Acess Flickering
Indirect connection
Remote access keeps dropping out
Viewing my libraries from different geographical location
Plex Media Server not showing my local server nor option to add one
"You are not connected directly to this server so streaming quality may be limited."
Remote access set up
Indirect Connection,
Remote server temporary connects then disconnects. probably no CG-NAT
Dreaded "Not Avalilible Outside your Network"
Not seeing contents of my Plex library when remote
No Remote Access, no direct connection
Plex Server Fernzugriff (Synology NAS und Fritzbox)
Poor streaming quality outside household
Web app can connect, apps can't
Unable to remotely access my server
Remote Access - Drives Not Showing Unless I Mount Them
(Plex remote access port mapped, but the port is unreachable from Plex.tv)
Remote access always so slow on iOS since it stopped being free
Remote access unavailable
Low bandwidth
Limited Quality 2 mbps
Help with Remote Access to server - in simple language please!
Untrustworthy "Not available outside your network"
Not available outside your network!
Mac media server
Remote Access suddenly not working
Remote access issue help
Video quality low and remote access not working
Remote access says accessible outside local network, but it does not work
Remote Access has stopped working - only change is Plex Server Updates
I tried everthing, remote access down
Direct connection on LAN, Remote Access not working
Remote access error - Not available outside your network
All remote content suddenly streaming as local
Will Hard Accelerated Transcoding Increase the Web Player's Maximum Quality?
VPN is it really needed
Cant connect to Plex outside local network
Unexplained remote access disconnect
Remote Access No Longer Working - Only changes would be NAS Software and Plex Server updated
Problems accessing Plex Server without using Plex Relay Service
Remote Access Service
Remote access only 2mbps
Remote access works sporadically at best and streaming is very slow
Changed ISP - No Remote Access with AT&T BGW 320-500
Indirect remote access since new ISP
Plex Transcoding and Remote access issues
No plex server found w/ remote connection
Downgrade of the quality image, need help
TP-Link buffering
Remote Access Continuously Disables
Remote Access Stopped Working but showing as working?
Can I Access Both My Own Library and My Friend's Library?
Plex remote play
Remote access confusion
Why is my media server running out of upstream bandwidth?
Will there be a speed limit for Sever?
Locked out again... it's Plex
I do not know what to do / remote access not possible
Remote access drops after connecting for a few seconds
I've tied everything to no avail. Is it because Plex is behind a LAN Extender?
Remote Access is broken
Checking my account for not acessing PMS from oustside(no remote access)
Opening port 32400 on Verizon router
Issues with Remote Connection
Remote Access. Port forwarding set up. It shows available, I refresh my browser, not available
The remote access for Plex is extremely slow in other devices
Plex server unable to connect to outside
Delete commercials
Lost remote access, I can't set it up again. Please help
Not available outside the network.
Remote access port issue - only 32400 is working?
Unable to enable remote access
Remote Access Off Line--since new iMAc
Trying to establish my Remote Access Connection!
Quality movies outsite home
Can't connect remote account to server
Cant resolve issue 320p library access friends
Plex not working outside network
How to watch Plex Media Server content when out of the house
Plex keeps losing remote access
Remote Access - Not available outside your network
Acces à distance[Résolue]
Remote Access To Plex Server Keeps Disconnecting
Remote Access not reachable outside network
Keine direkte Serververbindung, schlechte Streamingqualität
Please Help: problems sharing media, transcoding
Server sign in
Low quality but fast enough connection
Need help with Plex server connection
Plex bockt nach Hardwaretausch
Not available outside your network issues
Configuring Remote Access with a Netgear XR1000
Not connecting to server & bad quality! helpp! frustarting!
Why it should be this complicated to access your own server?
I can't access from web/android app to my server
Remote connection not working in any way
Plex server will not remote access no matter what
Download via Android or IOS APP over Internet not possible, only with Webbrowser
Newb needs help
Remote Access doesn't work off of network
Remote access not available depsite forwarded port
Remote access
Remote Access Throttled under 2Mbps - 1.31.0.6654
I have such an odd networking issue with a weird very temporary fix. Searching for fix
Remote access is not working
Plex remote works *sometimes* and I can't figure out why
Plex crashes when trying to run new version
I am having issues with Server Not Available outside your Network
Nvidea Shield server and ports
(4) Plex still ignores ipv6 remote access in 2022
I suppose that’s covered by Review your internet access / remote access configuration and the statement that you need a publicly routable IPv4 address.
On the other hand, the assumption isn’t entirely true:
I have an IPv6 only setup by my ISP and can access my server from outside my home network (based on an IPv6 port forward). Even if Plex Web complains that remote access isn’t available.
However… IIRC this currently only works with the Plex clients for iOS and Apple TV.
4 posts were split to a new topic: Setting up remote access
So at the end of this nice instructions/guide how to configure remote access you mentioned:
that is painfull process to go through if you are lucky :wink: Do know there are sites like port checker that looks all open ports of you router (if you provide you router IP or ISP number). this will help to make it easier and not to have to go a long way before open unused port is found.
I use the following online port checker tool —> Open Port Check Tool - Test Port Forwarding on Your Router
There’s lots of services that’ll let you scan individual ports (and probably also port ranges). I suppose many routers will not respond if they recognize that scan to be some kind of attack.
That being said… scanning your own router for restricted ports isn’t the same as checking which ports might be blocked by your ISP. There’s obviously a correlation but the blocking might just as well happen on your router (e.g. if it has some kind of protection against brute force Scans or simply because that particular port isn’t actually forwarded).
Asking the ISP might be much more straightforward.
A post was merged into an existing topic: Remote Access has stopped working - only change is Plex Server Updates
7 posts were split to a new topic: Remote access issues after equipment change
Still the case in 2023.. More and more ISPs only provide IPv6 in my Country and the public IPv4 is shared for many customers, thus public access only works via IPv6. I can access my plex server using my own domain using ipv6, however using the plex apps it still tunnels through the slow plex proxy instead of directly going to the server. Any way to fix this?
Which apps exactly are that for you? IIRC the server itself will handle IPv6 connections (except the remote access status indicator might be thrown off). But I remember having some properly working remote connections from iOS/tvOS and Plex Web in my old apartment (with an IPv6-only ISP).
If I read the release announcements correctly, the regular desktop client (Plex for Mac/Windows/Linux) might also work. I don’t have confirmation for the other clients but I could imagine the Plex clients will in some cases depend on how their host OS (e.g. the smart tv / gaming console…) handle such a network setup (or what APIs they allow/offer to do so).
Some users apparently got things to work by adding their IPv6 address as a custom access URL (server network settings).
